Old 06-26-2007, 04:50 PM   #1 (permalink)
Alternator Testing
Hello everyone. Guess my 1993 E350 is getting old. I have a charging problem I believe. My amps light is illuminated on my instrument cluster. I disconnected the main battery and removed it. The smaller battery is new a year ago. I replaced the bigger battery with a new one as my charger was tripping out charging the old one at 6 amps charge.
I thought it was the problem but the light is still on. I connect a volt meter to the new battery which is in series with the smaller one. I am reading approx. 13 volts. with the engine off. I start the engine and check the voltmeter. Still reads 13 volts. I turn on the headlights, fan blower and check again. Still 13 volts. It's not moving so I am suspecting the alternator. Is there a simple procedure on checking the alternator or even the built in voltage regulator for a fault?
I have tried searching the forum on this with no luck. Any help would be appreciated.
1993 7.3 E350 Non-Turbo Diesel Van,
Modified 3" Exhaust, Mega-Flow RV Muffler,
Auto Meter Pyrometer
Mingomya is offline
Old 06-26-2007, 05:01 PM   #2 (permalink)
Re: Alternator Testing
You need to remove the alternator and take it to an auto parts store where they will bench test it.
Be ready for sticker shock for the 3G alternator.
*ASE Master Certified, Medium & Heavy Trucks*
Mr_Roboto is offline
Old 06-26-2007, 05:38 PM   #3 (permalink)
Snotzalot's Avatar
Wiggle the plug on the voltage regulator and test your voltage again.
Regards,
Paul - Pocono Mtns. USA '90 E350 7.3L Ex-Ambulance High Top 400K Miles, No Turbo, Stock Stock stock, 10 oz. Bars Stop Leak and No ELC!
7.3L Alternator Belt Idler Photos
Snotzalot is offline
Old 06-26-2007, 05:47 PM   #4 (permalink)
On the voltage regulator? Is that the wiring harness on top of the alternator? I am sure the regulator is inside the alternaor, correct?
Anyway, I did wiggle all the wires on the alternator with no difference in the reading. But Thanks.
Mingomya is offline
Old 06-26-2007, 08:41 PM   #5 (permalink)
asauer's Avatar
Send a message via MSN to asauer Send a message via Skype™ to asauer
Stick a wrench to the back of it where the sealed bearings are (the little metal 'freeze plug' looking cap)...if it's charging the wrench will be magnetized to the bearing cap. If it's not charging, you won't notice the wrench pulling to the alternator at all.
[img]/ubbthreads/images/graemlins/smokin.gif[/img]
--motor/trans sold--
2000 VW Jetta TDI = 48+mpg
1997 Dodge 3500: 2WD Cab & Chassis, 12V Cummins, 47RE Automatic, Dana 80, 194,000mi. Parting out.
1989 12V VE Cummins out of Chevy C60? at the machine shop...going into the Ford.
Member of Indiana Air National Guard 122FW MXS
asauer is offline
Old 06-27-2007, 12:39 AM   #6 (permalink)
cdnsarguy's Avatar
My Photos: (74)
The light goes out when there is a charge......... You could check the brushes for worn out......was it ever flickering before quiting, if so I would say brushes. If it OEM the brushes have probably worn grooves in the armature.
Proud Canadian BOOB man too!!
cdnsarguy is offline
» Sponsor Links
»Garage Storage and Cabinets
