Old 05-23-2007, 08:53 PM   #1 (permalink)
ambulance and other oddites
hey i just got an 88 f250 with the ambulance package and i was wonndering if anyone could tell me more htank you also i will probly ask about a few other oddites like the infamous 10 ft bed
i just bought my first vehicle and it is a 88 f250 with the ambulance package (bigger alternator duel batteries more power etc.) 4x4 7.3l diesel with rebuilt E4OD tranny for towing BIG loads srw with drw axel gets bout 16 mpg (not lieing)
hotrod220257 is offline
Old 05-23-2007, 11:32 PM   #2 (permalink)
cdnsarguy's Avatar
My Photos: (74)
Re: ambulance and other oddites
Check my gallery, there is a TSB on ambulances..... shows a red X but click on the pic it will show up..... if not give me a heads up ....
Proud Canadian BOOB man too!!
cdnsarguy is offline
Old 05-24-2007, 04:10 PM   #3 (permalink)
hey thanks ill look for a battery cutoff but i think i should be more clear so its got the package but has a standard bed so its ambulance ready and i do not have an overdrive it was removed to rebuild the trans that year there were a lot of problems with the overdrive system
but thank you and i think if i do not have a bat cut off i will install one it may be a good idea
Old 05-24-2007, 05:18 PM   #4 (permalink)
My Photos: (17)
If you still have the E4OD transmission, we can help you get it working in OD. It's usually just a matter of getting all the electronic sensors working and set correctly. [img]/ubbthreads/images/graemlins/smokin.gif[/img]OkieGringo
<font color="red">1987 F350, 4X4, Crew Cab, DRW, w/'91 7.3 TURBO-CHARGED BY ATS, no-Wastegate(Turbo rebuilt by me 7/2005)</font>, <font color="blue">E4OD Auto, Aux Trans Cooler w/12" fan, w/Baumann Programable Trans Computer-12/05</font>, Rebuilt Injection Pump-2/03, Electric Fuel Pump, Coolant Filter, "BajaGringo Block Drains, 5-Row Radiator Core-9/04, 2 New Plastic Fuel Tanks w/new Sending Units/Pickups, Fuel Filler Neck Mods, Air Ram Intake, Air-Lift SuperDuty AirBags with Smart Lift Auto Leveling-7/2005 <font color="blue">Link to Photo of "OkieGringo Idler Pulley"</font>
<font color="red">Link to GP Controller Diagram</font> <font color="blue">Link to "Electric Fuel Pump Wiring Diagram"</font>
OkieGringo is offline
Old 05-25-2007, 01:30 AM   #5 (permalink)
hey sounds good ill look and see i no its an automatic but it was rebuilt to haul an 8 ton load so idk if anyhting is still on it for od wats the easiest way to tell what tranny it is?
Old 05-25-2007, 07:02 AM   #6 (permalink)
cdnsarguy's Avatar
My Photos: (74)
The E4OD has outside bracing for the case, looks like squares and is much larger than a C6.
Old 05-25-2007, 09:26 AM   #7 (permalink)
I believe the E4OD also has "METRIC" stamped onto the bottom of the pan...
My pics...
Sorry to all the loyal 7.3 guys, but I traded my '91 7.3 in on a 2002 F250 Ex cab V10 4x4. SCT Xcalibrator2 with tunes by Powerplay Performance. 285/75/16 Toyo M/T's. Took a long time to get used to the ping-pop of a cooling catalytic converter...LOL.
'85 Bronco swapped up to a 302 4bbl from the 300 I6, NP435 4spd, NP208, 32x11.50x15 Radial RVT's, Soon to be 6.9 turbo powered.
86 F350 Cab&Chassis with a dump bed. 2wd 6.9 and 4 spd tranny. No mods to engine.
2000 Volvo 660 N14 Cummins, 500hp 1650 ft lbs, Autoshift tranny 10spd.
What part of "SHALL NOT INFRINGE" do you NOT understand?
aceohearts is offline
Old 05-25-2007, 07:47 PM   #8 (permalink)
My Photos: (17)
I think you can tell by the number of bolts holding the pan up, but I don't remember how many. Anyone else remember? [img]/ubbthreads/images/graemlins/shrug.gif[/img]OkieGringo
Old 05-25-2007, 11:06 PM   #9 (permalink)
Bill1013's Avatar
If the original E4OD pan is on there it will say METRIC, looked at mine all day today, sure is a bunch of bolts on the pan.
99.5 F350 XLT Lariat 4X4 AT 4.10 DW CC LB Centurion conversion Garret Turbo Radio SD & Tape 126,700 03/08 Build date 03/99
Rebuilding engine. 92 F350 7.3 IDI CC LB dually Banks turbo US Gear O/U ENGINE IS SHOT !
1990 F350 XLT Lariat 7.3L IDI E4OD Dually 280K+ 2WD
Reman Promar Long Block 11/07
Reman IP - New Delphi Injectors Beru GP's New radiator & hoses New WP
Dual Exhaust 3"X18" resonators
Soup bowl gone, 4" intake W/AZ filter
Cobra CB W/Weather Interrupt - Dual Trucker Antenna's
Blk. Grill W/Brush Guards - Fog lights - Rally driving Lights. GN 20K & Reese 16K 5er hitch
http://community.webshots.com/user/oldbull8?
Formally OLDBULL
Toys: 1984 Coachmen Leprechaun F350 Chassis 460CID 92K miles.
30 ft. Jayco Jay Designer 5th wheel.
Have AutoEnginuity W/Ford enhanced. Lima OH area.
My mind works lightening fast.
One flash and it's gone.
Bill1013 is offline
Old 05-25-2007, 11:12 PM   #10 (permalink)
cdnsarguy's Avatar
My Photos: (74)
20 bolts, Metric and Ford insignia on the pan..... E9TP-EA is the assembly part # on the tag.........just back of the MLPS.
Old 05-27-2007, 02:22 PM   #11 (permalink)
well i think it is the E4OD because it is big and has a lot of bolts, it did have od at a point in time (found the cut wires off the drivers side mid way back about 6)i did not see metric or ford on the pan but it was rebuilt so the pan may be repro
if anyone has any diagrams please help id like to get this working
Old 05-27-2007, 07:15 PM   #12 (permalink)
My Photos: (17)
Send me your email address and i'll send the diagrams I have. OkieGringo
» Sponsor Links
»Garage Storage and Cabinets
