annoying white smoke - Diesel Forum - TheDieselStop.com
Old 10-14-2009, 04:37 PM   #1 (permalink)
94_idi_non_turbo's Avatar
Ok here's the thing my truck runs very good for being a 94 the only thing thats been really bugging me lately is that she smokes white sometimes very little and sometimes alot most of the time just as it's idleing although i have noticed she does it when i run her hard ............ at first i thought it was a bad fuel filter so i changed that nothing changed . I doubt that theres somethin wrong with any of the lines as they were replaced right before i bought her . I also run ULSD fuel but i mix in some Power Service fuel additive does any one have any info that can help me stop this annoying white smoke ??
Thanks in advance
94 Ford IDI Non-Turbo - E40D Trans. 4:10 rear end - Front end 2" lift - New brake system - New FOREST GREEN paint job - sitting on brand new 285/60/18 BF all-terrain with 18x8.5 MB motoring Predator rims - new motorcraft radiator and hoses - new motorcraft idler pully - almost forgot about my 3" exhaust w/no catalist converter , straight through muffler and 5"x8" rolled edge tip makes a mean throughty sound (LOOKING FOR POWER GAINS )
also have a 1993 mitsubishi eclipse 1.8L SOHC 5spd manual with what i call a fart can exhaust HaHaHa(weekend toy)
94_idi_non_turbo is offline
Old 10-14-2009, 11:54 PM   #2 (permalink)
cdnsarguy's Avatar
My Photos: (109)
When was the timing last checked......
Does the timing advance lever work on the left side (DS) of the IP.....
Air intrusion can cause white smoke......
Proud Canadian BOOB man too!!
cdnsarguy is offline
Old 10-15-2009, 06:48 AM   #3 (permalink)
Snotzalot's Avatar
Pete,
I have a similar white smoke problem at start up and I suspect no advance. How do you check/service the timing advance lever?
Regards,
Paul - Pocono Mtns. USA
02 E350 15 Passenger, 52,000 Miles
'90 E350 7.3L Ex-Ambulance High Top 400K Miles, No Turbo, Stock Stock stock, No ELC! (Extended Life Coolant) & 10 Oz. Bars Stop Leak, Retired 11/8/2011 with blown trans.
7.3L Alternator Belt Idler Photos
Snotzalot is offline
Old 10-20-2009, 09:21 PM   #4 (permalink)
I dont think that the timing has ever been checked well i know that i at least havent checked it in the 10 months i've owned the truck . Ill need to check the timing advance lever to see if it works and as for air intrusion i highly doubt it but ill check that out too thanks for your input
Old 10-20-2009, 09:37 PM   #5 (permalink)
How's the water level in your radiator look?
1997 F350 XLT Crew Cab Dually, 7.3 Powerstroke, 4:10 gears
badbart is offline
Old 10-20-2009, 10:23 PM   #6 (permalink)
Advance your timing a bit and see if the smoke goes away. White smoke that stings your eyes is usually late timing. As these IPs wear the timing slowly retards. If this clears up your smoke have the timing set correctly.
Evel486 is offline
