Old 05-23-2005, 04:50 PM   #1 (permalink)
My Photos: (5)
Send a message via AIM to lgettler
Antiloock light on dash stays on
I have a 1990 7.3 IDI (see info below) My antilock I guess RABS light comes on when I turn on the key and when I start the engine the light goes out. When I move the vehicle a few feet the antilock light on the dash comes back on and stays until I shut off the key, When I repeat the process it does the same thing. Any help on what is the problem
Could it be in the RABS circuit of what. Help
Will it hurt to drive with the light on?
Larry
If It's not broke, Fix it until it is broke.
My Gallery
1990 Ford F250 XLT, 7.3 IDI with E40D and 3.55 rears, Banks Sidewinder Turbo with 3 inch Flowmaster Delta Flow muffler, Transmission Temp Gauge, Boost Gauge and Pyrometer gauge and a new paint job. Better known as the Grayhound, long legged, fast and powerful. Retired Truck/Bus driving Instructor
lgettler is offline
Old 05-23-2005, 04:57 PM   #2 (permalink)
Re: Antiloock light on dash stays on
I wouldn't assume the ABS circuit is bad. I started having intermittant ABS light on my 1992 F250 and was tempted to blame the light. Lots of rear brake work later (bad cylinder, worn shoes, sticking emergency brake) I concluded that it was a good thing I actually checked the brakes out. Now, no light except on startup and dramatically improved braking. Good luck.
1992 F250 stretch cab, non-turbo 7.3 Jasper rebuild tested at 185 HP by Jasper; 5 speed manual; converted to dually with proper axle, wheels, brakes, springs; converted to 8x8 flatbed; 3.5" exhaust south of the Y-pipe. Various things replaced, but all pretty much stock.
SteveBemis is offline
Old 05-23-2005, 06:40 PM   #3 (permalink)
My Photos: (5)
Just installed new brake shoes, seals and cleaned the system good. New brakes really stop the truck. E-brake works good. sets and releases good. next thing to check is the RABS sensor. I will also replace the old fluid.
I noticed when I crawled under I felt the differential housing and it was very hot to the touch after driving solo for 22 miles, is that normal? any other suggestions
Larry
My Gallery
lgettler is offline
Old 05-23-2005, 08:28 PM   #4 (permalink)
I have the same trouble with my truck with the light on. i just did the rear cables, shoes and a hold down kit and the light is still on. Not sure of the trouble.
GREG
1989 F-350 SPEED 7.3
EXTENDED CAB
FIRST DESIEL LOOKING FOR TIPS.
gmdemo06 is offline
Old 05-24-2005, 09:34 PM   #5 (permalink)
try the sensor on the rear diff
my photos
95 f-250 444e e4od 4X4 ex cab long bed 3.55ls White Knight Reverse Lights, AIC, FORD seatcovers, AFE STAGE2 INTAKE, 3" downpipe 4" exhuast, EDGE Evolution 100hp setting, auto meter ultra lite pyro, tranny and boost gauges, .177bb in FPR, amsoil atf in transmission & tcase, amsoil syn gear lube in rear diff, bilstien shocks, fog lights
************future mods************************
intercooler, smaller turbo housing, window tinting
85 vw golf 1.6L stock
traxmedic is offline
Old 05-25-2005, 08:23 PM   #6 (permalink)
My Photos: (16)
I have the same problem and a Ford Diesel mechanic told me there was a sensor under the hood right behind the passenger side battery that can cause problems with the light. I'm at work now so I can't provide a picture of it for you. I have not tried replacing this myself yet so I'm not sure if that is the cause of mine being on or not.
2004 F250 164 Kilometers. Bought in Nov/08
My Pictures
Hugh Kennedy is offline
Old 05-28-2005, 10:36 PM   #7 (permalink)
Powerstrokedogg's Avatar
Send a message via ICQ to Powerstrokedogg
i have the same problem
and i just replaced the sensor in the rear end, still no change [img]/ubbthreads/images/graemlins/vulnerable.gif[/img]
2001 F-350 7.3L 4X4(ESOF) CC LWB 4R100 4X4, WIX 46637 open element air filter, Wicked Wheel, walker BTM, 203* Tstat, IC tube foil removed, coolant filter, AIH removed, 08 aluminum finned rear end cover, DP tuner 80econ 140smoke high idle,Phantom gauges, ATS transmission,ATS deep trans pan, 5 star torque converter, V10 trans cooler, 4" MRBP SS downpipe, twin 4" stacks
1989 F-250 6.9L IDI E4OD 500,000+ miles(sold)
1982 VW rabbit 1.6L diesel
Powerstrokedogg is offline
Old 05-29-2005, 08:27 AM   #8 (permalink)
cdnsarguy's Avatar
My Photos: (74)
lgettler and Hugh I have emailed RABs info for your trucks to you both enjoy...........
Proud Canadian BOOB man too!!
cdnsarguy is offline
Old 05-29-2005, 06:30 PM   #9 (permalink)
My Photos: (16)
Thanks Peter
My Pictures
» Sponsor Links
»Garage Storage and Cabinets
