Old 01-24-2007, 08:29 AM   #1 (permalink)
Any problem with putting a turbo on 7.3 IDI
Is it adviseable to put a turbo on a non-turbo 7.3?
Have a choice of engines either a 1989 or a 1992. It will be used for predominately towing, in a 1989 F350, 2wd, Automatic Transmission.
Thanks, Gene
redneckerson is offline
Old 01-24-2007, 11:01 AM   #2 (permalink)
My Photos: (17)
Re: Any problem with putting a turbo on 7.3 IDI
Well, if you don't put a turbo on, you ain't gonna tow anything unless it's all downhill to where you are going, and back again [img]/ubbthreads/images/graemlins/rolleyes.gif[/img]. [img]/ubbthreads/images/graemlins/smokin.gif[/img]OkieGringo
<font color="red">1987 F350, 4X4, Crew Cab, DRW, w/'91 7.3 TURBO-CHARGED BY ATS, no-Wastegate(Turbo rebuilt by me 7/2005)</font>, <font color="blue">E4OD Auto, Aux Trans Cooler w/12" fan, w/Baumann Programable Trans Computer-12/05</font>, Rebuilt Injection Pump-2/03, Electric Fuel Pump, Coolant Filter, "BajaGringo Block Drains, 5-Row Radiator Core-9/04, 2 New Plastic Fuel Tanks w/new Sending Units/Pickups, Fuel Filler Neck Mods, Air Ram Intake, Air-Lift SuperDuty AirBags with Smart Lift Auto Leveling-7/2005 <font color="blue">Link to Photo of "OkieGringo Idler Pulley"</font>
<font color="red">Link to GP Controller Diagram</font> <font color="blue">Link to "Electric Fuel Pump Wiring Diagram"</font>
OkieGringo is offline
Old 01-25-2007, 08:08 AM   #3 (permalink)
Okie, that is just not true, I have pulled my 30' fithwheeler without a turbo many times. Just slower going up hill.
Jim
<font color="blue">[b]93-F250 (Super Duty), Extended cab, Long Bed, XLT, Gray & Black, 7.3L, New Injector Pump, New Injectors 4X4, ZF5 5 speed trany, 4.10 gears Limted Slip.</font>
<font color="red"> Click here to check out My $800 Texas Truck</font>
<font color="green"> My 30 ft Wilderness 5th wheeler after new paint job and striping.</font>
<font color="purple"> The 2004 IDI rally in July</font>
<font color="red">Life, Liberty and the Pursuit of All Who Threaten It </font>
ltl_jrw is offline
Old 01-25-2007, 08:40 AM   #4 (permalink)
youll be able to tow anything, It just depends on how fast you want to go.
1993 Ford IDI 7.3L
F-250
ZF-5 speed 4 wheel drive
Class 5 hitch
D load tires &lt;img src="/ubbthreads/images/graemlins/frown.gif" alt="" /&gt;
super cab
18x,xxx miles.
Purchased 9-22-06
luckys420 is offline
Old 01-25-2007, 10:46 AM   #5 (permalink)
Only people with turbo's say you can't tow without one!
A turbo does make a diesel a more "pleasurable experience".
*ASE Master Certified, Medium & Heavy Trucks*
Mr_Roboto is offline
Old 01-25-2007, 04:15 PM   #6 (permalink)
Non turbo 7.3s are built a little different inside than a turbo 7.3. I believe 5 to 7 pounds of boost is all that is recomended.
'91 F250 SuperCab 4X4 Stock IDI 2 tone brown E4OD
'88 F350 Crew SRW (now parts)
'97 Aerostar 4X4 Extended 4.0
'93 Sable 3.8
'92 Taures 3.0 sold
'84 Bronco II 2.8 4 speed 4X4
'84 Ranger 2.8 2X4
'50 F-1 V8 Flathead 4-speed non syncro(bought new)
'76 Honda 250 Multi Sport(enduro)
mont91 is offline
Old 01-25-2007, 04:29 PM   #7 (permalink)
a buddy of my put a non wastgated turbo on his 93 ford 7.3 and all he does now is work on it is pretty mutch a pos now.
1991 ford f-350 XLT 4x4 Reg cab Flat Bed,7.3L IDI all stock, 5spd and 4.10 (very loud)
1992 ford F-150 XLT 4x4 auto with a 5.0,
Just a Broke High Schooler
fordtrucks is offline
Old 01-25-2007, 05:23 PM   #8 (permalink)
I need to clarify the intent of my question, My dad just purchased a 1989 7.3 IDI and would like to put a turbo on it. I would like to know if this is adviseable, responses like above about the amount of boost is helpful. The endstate is that the engine not crack pistons, blow head gaskets etc... any help with your experiences would be appreciated.
Thanks, Gene
Old 01-25-2007, 05:36 PM   #9 (permalink)
My Photos: (17)
Jim
Well then, I guess you've never towed out west of the Mississippi [img]/ubbthreads/images/graemlins/rolleyes.gif[/img]. That's my story and I'm stickin' to it!! [img]/ubbthreads/images/graemlins/smokin.gif[/img]OkieGringo
Old 01-25-2007, 06:41 PM   #10 (permalink)
I run a 93 F-250 with a Banks Sidewinder on it and about 80,000 miles later in runs great and I've had no problems AT ALL....
Just a little cramping in my face from driving it and grinning to much. [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
Don't hesitate go for it.
Good Luck
Marc
97 F-250XLT 4X4 C/C SHORT BED PSD, D60 FRONT AXLE CONVERSION TYMAR OPEN AIR INTAKE, FULL 4" EXHAUST, DP 3 POS CHIP, BANKS BILLET TORQUE CONV.ISSPRO TRIPLE SET
97 HOLIDAY RAMBLER 32.5' 5TH WHEEL ALUMALITE
97 F-350XLT STD CAB 4X4 PSD, BANKS STINGER PLUS KIT
87 F-350XL 4X4 STAKEBODY 6.9 5 SPEED YEARS OLD) OLD ENOUGH TO SMOKE
77 F-250CUSTOM 4X4 CREW CAB SHORT BED 400M C6
06 TAHOE LT
96 HONDA FOREMAN 400
GONE 3/6/07 BUT NOT FORGOTTEN LONG LIVE THE IDI
93 F-250XLT 4X4 4" BANKS SIDEWINDER+STRAIGHT PIPE, AND STRAIGHT AXLE CONVERSION
Supercab79 is offline
Old 01-25-2007, 07:28 PM   #11 (permalink)
Thanks, Gene
Yes it can absolutely be done, and be done safely.
The benefit of a turbo on a diesel isn't so much the "boost" but the ability to increase the air flow faster in acceleration....
Basically an NA diesel when you accelerate, you add more fuel and things go way rich until the engine RPM increases and more air gets drawn in. With the turbo, you have more air available so the engine is able to utilize the additional air sooner and more efficiently. So you don't need "big" boost numbers to have a better driving experience. Running a turbo with moderate boost levels will improve acceleration, efficiency and reduce smoking under acceleration.
It's only when you start trying to get substantially more power than the engine was designed for that you will run into problems.
If I had a diesel truck worth keeping, it would be turbo'd in a heartbeat.
Old 01-25-2007, 10:57 PM   #12 (permalink)
Dave Haven's Avatar
My Photos: (16)
My only problem after installing my ATS turbo was that I kept kicking myself in the @$$ for WAITING OVER 2 YEARS TO DO IT. And the cramped face muscles from grinning. [img]/ubbthreads/images/graemlins/laugh.gif[/img]
As of last week, I've put over 100K miles on "Big Red" since I installed the turbo.
If I had to do it over again, I would install the turbo as soon as I could afford it.
"Big Red"-'89 F-250 4X4 reg cab; 7.3; Cat ELC (no problems, ain't skeered ; 4.10 axles; 5-speed ZF "Bolt-Action"; ATS turbo installed @ 158K; Holley "Red" pump; new injectors and 2nd Reman IP@ 234.5K; "Coffee Can" (4") downpipe-back exhaust....
6220#
"Trick Truck"- 1970 F-350 w/custom utility bed and cabover camper; Cadillac leather seat; CAT 3208 w/turbo from CAT 613 scraper; 5" straight pipe; 6-speed Allison "slush box"; 3-speed "Brownie"; 2-speed Eaton rear axle from F-600; Custom rear deck w/ air compressor, Lincoln arc welder, Oxy-Acetylene rig, and boom crane....
17,940# 26' Class C motorhome
"White Pony"- 2007 Mustang; 4 liter V6; "5-shot bolt action" (an automatic in a Mustang is just WRONG!)
Dave Haven is offline
Old 01-26-2007, 12:41 AM   #13 (permalink)
My Photos: (17)
Dave, can you imagine trying to pull a 5th wheel trailer up to Flagstaff from Phoenix without a turbo. That is a mutha of a grade. OkieGringo
Old 01-26-2007, 02:38 PM   #14 (permalink)
Dave Haven's Avatar
My Photos: (16)
I once towed an 18' boat from Phoenix up to Flagstaff in my pre-turbo days. That was bad enough. I imagine a 5th wheeler would require another downshift or two on those grades.
