Old 11-01-2006, 11:12 PM   #1 (permalink)
Anyone put a weiand 8-71 blower on these engines?
I meen, the 8-71 blower started on a diesel (detroit to be exact), I'd need a manifold and pully.
Has it been done?
Results? [img]/ubbthreads/images/graemlins/smokin.gif[/img]
'93 Ford F250 w/ 7.3 IDI diesel (no turbo) E4od auto. SC/LB 2WD, but hey, got 3 attenas. retired government vehicle.
'26 tall T coupe on '67 scout frame w/400 Ford/C6
'00 Dodge Ram 1500 SC/SB w/318/5spd 4X4 3" SkyJacker lift 33-12.50X15 Perreli Scorpions
'01 Dodge Ram 1500 Quad cab/SB w/360/auto 4X4 NO LIFT!!! Running 33-12.50X15 Hi-Tech-Retreads with Green Diamonds (alternative to studs!) on saw blade chrome wheels.
'62 Caddy 2dr, "slammed" with air bag suspension. I can literaly set it on the ground!!!!
'48 CJ2A w/'61 over head valve engine
'77 Chevy Caprice, rare 2 door! Built 350 4 bolt mains. Weyand high ram intake, Headman Headers, dual glass pack "cop callers", TH350 with high stall converter and B&M "street/strip" kit (churps the tires hitting 3rd @ 90MPH!!!!)
'84 AC 5040 w/ loader
'71 Dodge D200 w/'69 vette 327 & powerglide
'97 Morgan built 20' tilt car hauler
'01 Morgan built 16'cattle trailer
Ford 9N
Ford 8N
JD model 40C crawler
shitface is offline
Old 11-02-2006, 01:34 AM   #2 (permalink)
Re: Anyone put a weiand 8-71 blower on these engines?
I've seen it done. It takes a lot of intake work and a lot of mousing around with the injection lines. I couldn't say how much it increased performance because I only saw it at a truck show and never had a chance to ask how it ran.
'88 F-250 7.3 IDI N/A, 4x4, ZF-5, 3.54, 285/75/R16 All Terrains, bowl removed, dual 2" custom exhaust with glasspacks (very unique sound)
'93 F-250 7.3 IDI N/A, future project
'88 F-250 7.3 IDI N/A, **spare parts**
'92 F-350 7.3 IDI ATS Turbo, 4x4, 4-door, ZF-5, 3.73, turned up pump, ISSPRO gauges, 6" I-beam bumpers, 35" Buckshot Mudders, custom 4" straight exhaust
'89 Bronco - future 7.3 conversion
faz_fordfreak is offline
Old 11-02-2006, 09:39 AM   #3 (permalink)
My Photos: (9)
It gets kicked around from time to time but since a turbo can make all the boost any engine can handle, and does so without robbing shaft horsepower (mostly), it would be a very expensive and inefficient way to do it. In semi trucks it was called an "iron lung" and went out back in the 50s or early 60s in favor of the turbocharger
Birken
Birken Vogt is offline
Old 11-02-2006, 10:43 AM   #4 (permalink)
When I worked at a diesel truck garage that serviced a truck fleet, back in the late 70's-early 80's, we had a couple of trucks that were blown AND turbo-charged (on the same engine). Can't remember what they where; really big Cummins I think. That contraption stuck up about 2 feet off the intake runners!
1992 2WD F-250 SuperCab 7.3L 5-spd 4.10 rear. Changed to 5w-40 Rotella Synthetic oil in the crankcase & Deep Purple Synthetic ATF in the Trans. 38K on new Jasper longblock, Bought truck from local University (MSU - 09/20/06). Replaced O-rings on return line caps with Viton. Now on to tackling Biodiesel!!
kleenax is offline
Old 11-02-2006, 11:31 AM   #5 (permalink)
From what I understand, the blower/turbo combo was used to cover the spectrum of boost given rpms. Blowers were used for the low rev boost until the turbo could spool up in the high revs. It's basically the same thing as modern day twin turbos; a small turbo for low rev and quick sool up, and the bigger turbo for high revs and max boost. Blowers can be geared to compensate for the low revs of diesel engines, but the classic argument is that blowers rob power. Anything with a belt robs power because it it pulling off of the crank. So, yes, a turbo would be more efficient. However, a twin stack of 8-71 blowers hanging out of the hood would be pretty sweet.
Old 11-02-2006, 11:52 AM   #6 (permalink)
My Photos: (12)
the turbo blower mix was on 2stroke detroits. v series engine had them off the top like a racecar does, the inlines were hanging off the side.
83 F250 6.9 rebuilt at 280,000. NP435, NP205, 4x4 conversion with hp60 front, 10.25 rear. 35inch Cepek Mud Countrys - RESTING IN PEICES (PARTED OUT)
99 Expedition 5.4 gasser
2000 F550 Lube Truck (Work Truck)
Certified PA Inspection Mechanic
i'd rather be 6.9'n than cummin or strokin'!
CowKiller is offline
Old 11-02-2006, 01:05 PM   #7 (permalink)
Those engines I believe were a 2 stroke diesel that needed the blower and turbo for proper induction.
Perry
1992 F350 Crew Cab, 7.3l IDI, LWB, 4x4, E40D trans, 170,000 miles so far.
http://www.pbase.com/drz400/truck
perryg114 is offline
Old 11-02-2006, 03:29 PM   #8 (permalink)
all the 2 strokes needed them to run, but the turbo motors were just there for the extra kick. Mainly because a roots style compressor losses efficency fairly quick.
Now, I must say having one on a 7.3 would be pretty slick, though I'm not sure how it would compare to a turbo on one.
88' F-350 reg cab, SRW, 4x4.
7.3/ZF5, 4.10's and 33's, rear locker,
banks turbo, 3.5" straight pipe, pump maxed, and advanced 2 degrees.
89' F-150, 351, 435, dual T-cases, rear discs, front electric winch, PTO winch rear, OBA, 40's
Jrod13 is offline
Old 11-02-2006, 09:45 PM   #9 (permalink)
My Photos: (12)
it would not add much power, since it isnt gona push that much "boost" and the power it takes from the crank to power it, on these engines i belive it wouldnt add much. there was a truck in petersons four wheel off road mag in the readers rides that had one. sharp lookin truck, but they put the intake hat back on WITH the butterflies still on it. i would remove the butterflies, get as much air in as possible. we dont need no stinkin' butterflies!
Old 11-03-2006, 08:20 AM   #10 (permalink)
My Photos: (23)
Somebody had stuck one on according to a recent ebay add I saw. It looked convincing enough, but as has been mentioned, a lot of work for not much more than bragging rights.
- Mel
1983 F-250HD 4X4 The Moose Truck - Moose Pump, DPS Injectors, Hypermax Turbo, GV 7spd., 3.54 Gears, Moose Air, RDT, Dual Stacks, 35"tires. My Album 55MPH at 1400 RPM. 19MPG Avg.
1993 F-350 CC DRW The Lady Moose - Hypermax Turbo, GV 9spd w/Double OD. 4.10's. Dual Exhaust, custom trim, turned up 6.9 fuel system, Lucky Flywheel.
1987 Bronco The Moosestang 1987 Bronco Diesel 6.9L C6 4X4 with 3.54 gears, 2" body lift.
HeadGasket/Turbo Article
A BOOB man! Visit EZBoard.com and search for IDI.
agnem is offline
Old 11-03-2006, 09:25 AM   #11 (permalink)
My Photos: (9)
You could drive it at a speed such that it would give you the same boost, and hence the same power, as a turbocharger, but the economy would be terrible (since you would have that amount of boost at all times whether you needed it or not) and the power would still be down a little since the supercharging power would be taken from the crankshaft and not the exhaust stream. Plus there would be a weight penalty and a maintenance hassle.
Birken
Old 11-03-2006, 01:46 PM   #12 (permalink)
What about the concept of a variable gear drive for the bolwer? Kind of like a CVT on the drive pulley that was enhanced as the throttle was advanced. I know that they make certain blower kits that have varying spool gears, kind of like a little tranny in front of the compressor. That would allow for different flow rates for different throttle ranges. Also, I haven't had the time to figure it, but in retrospect, people mount belt driven air compressors to their motors and they don't totally fall on their face, so why is a power adding device such a big deal when it comes to arguing power loss? Shouldn't it make up for itself in a sense? Granted, not nearly as efficient as a turbo, but I just hate to count things out, especially when they would look pretty sweet and be totally unique, which, after all, is the essense of hot rodding!
Old 11-03-2006, 03:44 PM   #13 (permalink)
My Photos: (9)
The air compressors are much less air volume than a Detroit Diesel blower puts out. It certainly would be functioning as a power adding device but only when the power is actually needed which is rare, the rest of the time it would be a power wasting device in a big way. A variable drive certainly would help matters a lot but it would still be worse for several reasons
1. Expense
2. Exhaust energy is still wasted, unharnessed, out the exhaust
3. The Roots style Detroit blower is very inefficient compared to the centrifugal turbocharger style
The bottom line is that given the same base engine, slightly more power could be made with the turbocharger than the blower because the turbocharger gets its energy from otherwise wasted exhaust energy, and also the efficiency standpoint.
Birken
Old 11-03-2006, 08:53 PM   #14 (permalink)
Dave Haven's Avatar
My Photos: (16)
[/ QUOTE ]Yup. And the air compressors also have a magnetic clutch that disengages them from the drive pully when they're not needed, as in most of the time.
Thanks for taking up the slack for me on these threads, Birken. [img]/ubbthreads/images/graemlins/wink.gif[/img]
Dave Haven is offline
Old 11-03-2006, 08:59 PM   #15 (permalink)
There's a lot of interesting theory in this thread. I think with a properly sized positive displacement blower these motors would run very well, much better under 2k vs the IDI turbo stuff I've run across. I would not run a 8-71 (inefficient junk), but a newer whipple style with an air - water after cooler ala the lightning or 2003 cobra. The real trick would be to size so it would boost correctly.
Jamie
Currently resurrecting a dead '94 CC 7.3T 5 speed with a 6.9 and ATS turbo setup.
1989 F450 7.3 N/A 5 speed wrecker with 5.13's. Removing the bubble gum and tape to fix it correctly...
1986 C30 Crew cab 4 sp 'Frankentruck' Cut it in half and welded on another 1 ton frame and then added a rollback setup. 30'6" monster
ranchero50 is offline
