Old 04-08-2007, 10:57 PM   #1 (permalink)
Anyone use fuel tank cleaners/sealers?
Hey all,
Found a rusty rear tank upon inspection, Has anyone used the cleaning sealing method with success? any recommendations on brands or methods would be greatly appriciated.
Thanks for any advice.
Eric
92 E 350 extended VAN, quigley 4x4, 7.3 idi, E40D, 4.10's,mitsu starter,Warn front bumper, captains chairs,33x12.5's,rear ac, pulling 22 Ft. Commercial Duty Whaler.Finally got my dream rides. Baja here we come...Well Almost anyway
JETTYCAT is offline
Old 04-08-2007, 11:24 PM   #2 (permalink)
Re: Anyone use fuel tank cleaners/sealers?
A buddy of mine tried the resealer didn't last very long. He said it would of been cheaper finding another tank. I ended up trading him one. The steel in the tank gets thin and flimsy does your tank feel solid ? I believe I got another if you need on. Hope this helps. Kevin
94 F350 CC pure idi powerhouse 93 F350 CC wifes favorite wagon 1988 F250 daughters ride can't seem to get the son to run diesel gotta have his ranger or as he would say slammin and jammin. just purchased 2001 F450 4x4 service truck powerstroke 6 speed..
dslmechanic is offline
Old 04-08-2007, 11:58 PM   #3 (permalink)
My Photos: (17)
I had rusty tanks also. I tried having them cleaned, but just ended up with pinholes. Had them braised but didn't last long either. Ended up buying both new plastic tanks from www.mtscompany.com Okiegringo
<font color="red">1987 F350, 4X4, Crew Cab, DRW, w/'91 7.3 TURBO-CHARGED BY ATS, no-Wastegate(Turbo rebuilt by me 7/2005)</font>, <font color="blue">E4OD Auto, Aux Trans Cooler w/12" fan, w/Baumann Programable Trans Computer-12/05</font>, Rebuilt Injection Pump-2/03, Electric Fuel Pump, Coolant Filter, "BajaGringo Block Drains, 5-Row Radiator Core-9/04, 2 New Plastic Fuel Tanks w/new Sending Units/Pickups, Fuel Filler Neck Mods, Air Ram Intake, Air-Lift SuperDuty AirBags with Smart Lift Auto Leveling-7/2005 <font color="blue">Link to Photo of "OkieGringo Idler Pulley"</font>
<font color="red">Link to GP Controller Diagram</font> <font color="blue">Link to "Electric Fuel Pump Wiring Diagram"</font>
OkieGringo is offline
Old 04-09-2007, 11:18 AM   #4 (permalink)
Thanks, Unfortunately I have a van and MTS doesnt make tanks for vans.
It is my rear tank. Seems pretty solid still. I am still trying to hunt down a tank, but I may have to muriatic acid treat then seal or no seal and use it. If anyone has a rear tank let me know please.
Eric
JETTYCAT is offline
Old 04-09-2007, 11:33 AM   #5 (permalink)
arthurgoboom's Avatar
I just used a wire brush cup that goes on a 4" angle grinder to clean all of the scale from mine, and I did find some pinholes mostly around where the tank straps wrapped and where it went under the cross members (front tank).
After wire brushing, I wiped it down with a rag with lacquer thinner on it, then brushed on this stuff called Seal All that can be found at auto parts stores or walmart. It's a clear sealant that says it is impervious to gas, oil, etc. After that I repainted the whole tank, then I sprayed that rubber undercoating (also at walmart) that comes in a spraycan over all of the areas where the straps/crossmembers ride. It seems ok so far...
1986 F250 2WD Super Cab XLT Lariat w/ 1996 front clip. Dually bed & van rearend (2" wider, allows spring clearance). 6.9 w/ approx 120,000mi. Banks non-wastegated turbo system, Beru ZD1A glowplugs, Delphi BB injectors, Kenworth pyrometer, vac/boost gauge, electric water temp/oil psi/voltmeter mounted in dash. 3" Mandrel-bent open exhaust. C6 trans, 3.54 gears. Okiegringo idler pulley. R134a A/C conversion. WMO/diesel blend in one tank.
arthurgoboom is offline
Old 05-10-2007, 11:24 AM   #6 (permalink)
Lots of ways for a DIY'er to clean and seal (if necessary) a gas tank. Just do a search on "cleaning a rusty fuel tank" or something like.
I've cleaned many with muratic acid and you end up with a new looking tank. I used short concete nails inside the tanks to scrub the tank. Add the acid, nails and shake, shake, shake. You get the idea.
Don't forget to remove the nails, they can be used on the next tank.
bluefishbeagle is offline
» Sponsor Links
»Garage Storage and Cabinets
