'93 F-250 XL Supercab Longbed
7.3L IDI
-These are not "mods", but they should help in troubleshooting, what I've replaced so far!
--Fresh rebuilt Tranny (E4OD), new tach sensor, new FIPL "sensor", Glowplug relay checks "OK", new VSS.
Re: Anyone used battery cables from CustomBatteryCables.com ?
Don't know anything about that company - I had some made for my truck at my local NAPA store - just took mine to them and they made them to fit right there in the store in about 20 minutes. Cost me $90 after sales tax.
Bob
I called my Napa and they said they don't make cables...called around to a couple other places and they don't either. I'm trying a trailer shop right now.
7.3L IDI
Doesn't look like it's happening, this town sucks.
7.3L IDI
Try Interstate Batteries, they were very good & cheap, last year I paidf about $54 for the positive cable from them ford wanted anywhere from $225-$258, for the ford cable, the interstate battery cable was made a lot better, then my old stock ford cable(also heavier gauge wire).
jerry
'91 F350 CC,7.3NA w/K&N,E40D(rebuilt--way too many times), 2WD,3.55 rear end,new IP,new u-joints & carrier bearing, new rotors, new calipers, new drums & hdware, added Auburn limited slip unit (2/8/05)w/valvoline synth 80-90w, new batt.cables,new window motors,new radiator & hoses, 500K, (new injectors)+ mi (now 678K miles)& still Truck'n. If I can fix it, it ain't broke, I'd rather do it myself.(yes, I add,stanadyne, lucas or power sytems fuel additive in every tank, w/maybe 1-2x year full big bottle dose split between both tanks). New tires & pretty wheels, front end rebuild 3/17/05. Bilsteins added 6/12/05. New motor mounts & valve cover gaskets (9/06.)Future hopes finally fixing my electric door locks & adding remote entry/alarm system. http://community.webshots.com/user/jl_mendoza
Try a boat place too. Lots of cables are custom made for that stuff.
94 F-250 IDI Factory Turbo. E4OD Auto 205k miles.
Banks Transcommmand. ATS 3" Exhaust. ATS Intercooler. Pre-Charged Coolant Filter.
Gagues: Autometer Pyro, Trans & Tranfer Case, rear diff, boost, 3 water temps, oil pressure.
Sams Club Goodyear Wrangler AT/D2 265/75R16LRE
02 X 4x4, 56K miles stock. Michelin LTX M/S 265/75R16LRE. 30MM Ford Sway Bar. DP Tuner 40T/80T/80E/120R. AIH delete, AFE Stage 2 PG7, MBRP 4" Turbo back, Coolant Filter, Baldwin Transfilter, lots of gauges, mag-hytec diff covers (front hits and is a waste of money) maybe some other stuff.
I'll give them a shot too, thanks [img]/ubbthreads/images/graemlins/smile.gif[/img]
...anyone else tried this place?
7.3L IDI
most semi tractor places make their own cables also--
