Old 04-07-2005, 02:28 PM   #1 (permalink)
Anyone with a wastegated Garrett turbo?
I have a wastegated Garrett turbo on my truck and assume that it is stock but I can't read all the numbers molded on the housing. What I have is "?R70 M4?" best I can read. The wastegate has a sticker on it with the numbers 430819-266 then under the first no. 06643 then under the second no. 12387
Does anyone have the same turbo that can read all the numbers. I don't have any problems; I am just curious to know what I have.
As far as the wastegate goes how would you test or know what boost its set at. No I don't have a boost gage YET! I don't know much about wastegates other than they open at a set manifold pressure. Are they adjustible or preset?
'93 7.3L (IDI) Factory Turbo F350 XLT Crew Cab 4x4, ZF 5-speed, LS 4.10
Stock truck for now.
barta is offline
Old 04-07-2005, 05:07 PM   #2 (permalink)
Re: Anyone with a wastegated Garrett turbo?
About all the of us have a garrett turbo, what is the 8th number of your vin, if it is stock its an ATS, i can check the numbers on mine this weekend.
Allen
93 F250, regular cab, 4x4, 7.3 NA, ZF5, 3.55, 209k miles, came home 2/28/06, soon to be turbo.
92 250, regular cab, 4x4, 7.3 NA, E4OD, 3.55, 316k miles, came home 8/28/04, aluminium 16x7 wheels, 285/75/16 Sport King AT.
89 250, extended cab, 4x4, 7.3, ATS wastegated, 5" straight pipe, hand shaker, 4.10, slightly toasted, waiting for a new cab and front end, came home 12/24/04
aaklingler is offline
Old 04-07-2005, 06:08 PM   #3 (permalink)
My 8th no. is 'C'
barta is offline
Old 04-07-2005, 07:48 PM   #4 (permalink)
Yep, you've got the factory ATS turbo, would you like me to check out my numbers, i think mine is one off a factory turbo truck but i'm not sure, is there anything else you wanted to know about yours?
Allen
Old 04-07-2005, 10:28 PM   #5 (permalink)
Thanks for the info. I see that yours is wastegated. Do you know how to check if it is working properly? The manual I have says if it holds 5psi its good but I spoke with a diesel service retailor and they said they are set at 9-10psi is this test correct?
barta is offline
Old 04-07-2005, 10:35 PM   #6 (permalink)
The number you should see on the aluminum housing is A/R .70 that means it is still stock.That is the Ratio value for the impeller housing.To tell if the turbine housing(exhaust side) is stock or not see if there is a Clamp ring holding the down pipe on.If not then it was upgraded since the ATS upgrade(only makers of upgrade stuff since they came up with the setup) has a slip fit down pipe.
IDI Till I Die!!!
NCC-1701UAV U.S.S. Enterprise -1991 F350 CC dually.Lighted heated west coast mirrors,Nathan Airchime K3HA air horns,attitude from hell itself!
1994 F350 Crew Cab Dually,7.3 IDI turbo-Currently in the Roundhouse awaiting 10 year overhaul. White Lightning
1971 M35A2 deuce and a half.6wheel drive,Power Nothing!125 Horses in a 13,000lb truck.Real get up and go power! Martyr Machine
Cousteau 2006 Ranger STX-3.0 V6,5spd handshaker,standard cab
m35a2 is offline
Old 04-07-2005, 11:06 PM   #7 (permalink)
i believe they are set for 9-10, you won't see more then 5 running around empty, probably, all you can do is hope that it isn't working, the turbo won't make more boost then what engine is can handle real quick, a lot of guys shorten the rod so that it opens later or not at all.
Allen
Old 04-11-2005, 12:09 AM   #8 (permalink)
I've got A/R .70 M43 BO cast into my intake housing and 8709-1 stamped into the intake housing just above it, i don't have any stickers under the hood left.
Allen
Old 04-11-2005, 02:06 AM   #9 (permalink)
Thanks for the info, that seems to be the numbers I have also. I was told by one of my local shops that the ford factory turbo is a Garrett TC43.
barta is offline
Old 04-11-2005, 12:32 PM   #10 (permalink)
I'm guessing they have the "43" part right, but i don't know what the difference is between the "M" and "TC", Garrett made the turbo, ATS put the kit together for the truck and Ford installed it.
Allen
Old 04-11-2005, 06:18 PM   #11 (permalink)
I was told that the numbers A/R .70 M43 BO is just a housing no. and not the actual turbo model. Where the model if ever you need a stock replacement Garrett TC43 is it.
barta is offline
» Sponsor Links
»Garage Storage and Cabinets
