Old 07-29-2006, 01:44 PM   #1 (permalink)
ATS oversized transmission pan
Are the benefits of this item really worth the cost?
Has anyone used these?
Thanks Mike
92 F250 XLT, ext. cab, 2wd
1morford is offline
Old 07-29-2006, 02:53 PM   #2 (permalink)
Re: ATS oversized transmission pan
Is it a steel or aluminum pan? If you hit a steel pan it bends and keeps holding oil. If you hit an aluminum pan it breaks.
If you have a 2wd you can switch to a factory late model 4x4 pan and gain about 1.5 quarts and a drain plug.
IMO good cooling is better than more capacity. More capacity simply delays oil overheating, since there is more oil to heat up. There is little air flow over a trans pan, so the cooling there is negligible, even with a fancy finned pan.
*ASE Master Certified, Medium & Heavy Trucks*
Mr_Roboto is offline
Old 07-29-2006, 04:06 PM   #3 (permalink)
Mr_Roboto,
That was kinda my thought, more oil just takes more time to heat up!!! even if they have fins.
Some of these companies say they lower temps 40+ degrees?
Any suggestions on better cooling?
1morford is offline
Old 07-29-2006, 05:32 PM   #4 (permalink)
after market trans cooler. That is the best idea,
And mine has it's own fan on it also.
1990 F-350 Dually 4X4 CC Rebuilt Turbo and NEW 7.3L DAS engine, rebuilt rear diff, Reman E4OD Stage 1 injectors Stage 1 pump Baumann recal kit and TDC for E4OD dead trans again...
2004 F-350 4X4 CC 6.0 PSD
2004 Wilderness 320dbhs TT
DSBlack is offline
Old 07-30-2006, 12:01 AM   #5 (permalink)
cdnsarguy's Avatar
My Photos: (66)
You could get a standard steel E40D 4x4 pan and 4x4 filter, which is slightly larger than the 2wd pan you now have.
Mercon fluid capacities E4OD
4x2.....14 liters/15.7qts
4x4.....15.3 liters/16.2 quarts
Proud Canadian BOOB man too!!
cdnsarguy is offline
