Old 10-22-2005, 11:55 PM   #1 (permalink)
ATS Turbo just installed...exhaust leak question...
Hey guys-
I just got done installing my ATS turbo system on my 92 IDI. The kit was purchased used and looks to be in fine condition. I also installed a MBRP 4" exhaust system and a set of gauges. My question is this: I seem to have a pretty good exhaust leak from where the inlet pipe and downpipe slip into the cast exhaust housing on the turbo. Is there supposed to be any sort of gasket in there? From what I could see on the ATS site, it looks like they just slip in there dry. The collector flanges mated up to my stock manifolds fine and seem to be sealed up, and the MBRP was easily mated to the 3" ATS downpipe with a little fabrication, and I don't believe it leaks there. When driving the truck, the exhaust leak can be heard thru the firewall and drives me nuts.
Driving impressions? Turbos rock. I knew that from my Supra, but had no idea how much a little boost would wake up my old Ford. The exhaust note with the 4" is awesome, and the extra smoke just pisses off the guy next to me at stoplights. I love it!!!!!!!
Ryan
1992 F250 4x4 5spd 81000 miles, slowly upgrading...
1984 Toyota truck- Rockcrawler- EFI Conversion, dual transfer cases, gears, lockers, 37's, etc...
1987 Toyota Supra Turbo- all the goodies 400RWHP
reklund is offline
Old 10-23-2005, 01:54 AM   #2 (permalink)
Re: ATS Turbo just installed...exhaust leak question...
Ryan if you have the old non-wasted gate ATS turbo then a small exhaust leak at the downpipe turbo junction is not abnormal and should seal itself up in a couple hundred miles. If it is more than a small exhaust leak you might want to make sure that the downpipe is fully seated in the cast iron turbo housing. Hope that helps.
Cam
91 F350 reg.cab, SRW, 4x4, Powered by a '98 Cummins 12v. BHAF, #10 plate, 3k gsk in the near future, Di-Pricol pyro and boost gauge and VDO oil pressure gauge in a custom A-pillar mount, 4" straight exhaust, PSD intercooler, 4.10's, ZF 5spd, 4" superlift, 305/70/16's
2001 Bullit Mustang, #292
[color:"black"]My Cummins conversion
[color:"blue"]Toy Pic's
[color:"red"]intercooler install
Radcam is offline
Old 10-23-2005, 10:44 AM   #3 (permalink)
Ryan,
When I put my Hypermax on, they recommended coating the periphery of the down-pipe flange (where it engages in the turbo housing) with so-sieze. Also check to make sure you're not actually hearing a pipe in contact with the firewall- it could be mistaken for a leak. Like the previous poster said, it'll likely seal up in a while. Good luck,
Keith
93 F350 CC Dually 7.3 Hypermax turbo 4:10 gears, ZF rower, K&N filter, home made ram-air, Hypermax 3.5" exhaust, LUK clutch, 150,000 mi.
Weezer is offline
Old 10-23-2005, 11:26 AM   #4 (permalink)
Thanks guys...
I did put some anti-sieze on the piping before I assembled it. I'm certain that nothing is contacting the firewall. I had a problem with that and it was LOUD in the cab. Thats been fixed, and I now have plenty of clearance around the downpipe. I guess I'll have to drive it some and see what happens.
Ryan
reklund is offline
Old 10-24-2005, 12:47 AM   #5 (permalink)
Drove it some more today, but still have leaks. It goes fast and smokes tho... [img]/ubbthreads/images/graemlins/phoney.gif[/img]
Ryan
reklund is offline
Old 10-24-2005, 07:47 PM   #6 (permalink)
typefour's Avatar
Hey radcam, I am wanting to put an intercooler in my truck when I do the Diesel install. what did you use for a cooler and what was the square tube pic for/. is there any text for the work you did. I can figure it out but the brain is old and slow sometimes.LOL
thanks
91 F350 crew cab 4x4 7.3 ats and intercooled with '04 ps cooler , ,coated rockers , balanced. very good power.
pyro,boost and all stock guages ignored with mechanical real ones
Fugitive sandrail. 2400 cc type4 engine, my baby
Invader sandrail, 1.8 jetta engine installing spinny thing soon.
83 300 sd ready to build a real hotrod engine for this one.
Misc. vw's scattered about.
typefour is offline
