Auto transmission options behind a 7.3 IDI - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 11-04-2010, 08:47 PM Thread Starter
Will a C6 fit behind a 7.3 IDI if the E4OD shoots craps and a C6 is readily available? Much/any fabbing required? Bolt-in?
Thanks,
D
Work like there is a tomorrow and play like there isn't.
99 F250 CC LB 4X4 255K AT
85 F250 SC LB 2WD with Banks aftermarket turbo, C6
87 F250 Lariat SC LB 4X4 with an NA 6.9, C6 with deep pan and 4.10's. Dana 50 IFS up front. 263K mi. 3" exhaust, Ram air. New aluminum radiator and coolant filter Sep 09. Parked due to horrible engine knock.
96 F350 CC LB 4X4 AT 292K- creamed by Brain Dead Cager turning left 02/18/10 RIP
DevoK12RS is offline
post #2 of 5 (permalink) Old 11-04-2010, 08:52 PM
Mark Kovalsky's Avatar
My Photos: (6)
The C6 was available from the factory, so it's a bolt in. You would need to get a C6 from a diesel.
Mark
Former
Automatic Transmission Engineer 1988-2007
Mark Kovalsky is offline
post #3 of 5 (permalink) Old 11-05-2010, 10:46 AM
cgraham's Avatar
These trucks suck w/o overdrive! Just make sure you get all the linkages and everything that goes with the c6.... I would recommend buying a whole parts truck so you can be sure you have everything you need. That's usually cheaper than buying all the parts individually. And you can see it in the truck, so you'll know where everything goes!
'87 F-350 CC 4x4 - 7.3 Banks Turbo, ZF-5 swap, 6" lift & 37" Toyo MT's & 17" Black Moto Metals!
2006 Dodge Ram Mega Cab - Cummins, 6 Speed, Leveled w/35's, Road Armor Bumper
1984 Jeep CJ-7, 258, 5 speed, lifted on 35's
cgraham is offline
post #4 of 5 (permalink) Old 12-11-2011, 08:11 PM
I have a 1992 7.3 idi with an e4od and it gave out.. I'm looking at a zf 5 Speed from a 1995 powerstroke, does anyone know if the 5 speed's bell housing will bolt up to my motor? If anyone knows anything then please respond ASAP.. Thanks
92IH-IDI is offline
post #5 of 5 (permalink) Old 12-11-2011, 09:14 PM
My Photos: (6)
I'm pretty sure it will bolt up.
Mark
Former
