Back on the road again ....almost?
And you thought you had heard the last of "Purple Faye" (my 7.3L Ambulance). HAH!
At the close of last season (Autumn) the engine gave up the ghost ...at barely over 200,000 miles! Obviously, the previous owner did not maintain it very well!
Attached as I was to the Ambulance, and lacking in all but the most basic mechanical skills, I opted for a rebuilt (Jasper) engine. It was installed by one of their recommended installers. Only recently having bailed her out, I am not confident of certain aspects of the job ...
1) The coolant they used was a pre-mixed concoction from CASTROL. It is PURPLE in color, and allegedly has SCA's already added. Should I insist on IH?
2) The "ALT" light remains lit solidly on the dashboard, while real meters (Volts, Amps) read within parameters.
3) The transmission overdrive light blinks, first with a code that required replacement of the TPS, then with a mysterious reference to Lean operating when throttle is wide open, and now with one that indicates slippage in overdrive.
4) At highway speeds, there is an up and down oscillation that is SO bad, I'm afraid the ceiling will cave in. Mechanic diagnosed this on the telephone, assuring me it was a tire that had a flat spot. Meanwhile, they had replaced a universal joint, and felt the driveshaft didn't require rebalancing. "If it were the driveshaft, the vibration would be much faster, it would feel like a back vibrator". Is this true?
Thanks in advance ...
AMMO
AMMODYTE(@>
'94 E-350 7.3L IDI/E40D 4wd conversion by QUIGLEY. "Star of Life" Ambulance (conversion by AEV). GVW 8400 # (without driver) Currently used as a beach vehicle and (Class B RV) camper. Those BILSTEIN RV shocks sure made a big difference!
285-75-R16 BFG T/A KO's on OEM factory (8 bolt) 7" rims. Dana 60 axles front & rear with 4:10 gears. Completely rebuilt JASPER engine installed, Winter 2005. Steel security screens under windows and American padlocks w/round hasps allow on-street parking. Towing mirrors. Independent cabin power (deep discharge) battery.
Future projects.
Pillar Gauges - Transmission Temp/Oil Temp/Oil Pressure
On Dash - Tachometer, Pyrometer
Add marker & clearance lights.
Improve air intake. Upgrade exhaust (at failure).
Add CB & VHF radios. DVD.
REPAIR CRUISE CONTROL!
Wanna see a picture?
http://photos.thedieselstop.com/show...t=1&thecat=500
