Old 03-11-2005, 06:46 PM   #1 (permalink)
Bad Head Gaskets...What next
OK,
Just got in from pressurizing the coolant system. [img]/ubbthreads/images/graemlins/vomit.gif[/img] I run it up to test pressure and didn't have to wait the said 2 min. Got underneath and found my leaks! Both HG's front and back were leaking substantially along with the block heater. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Didn't bother with cylinder comp tests as wouldn't be right.
Here's my options:
Replace HG's for $125.00
Run to the motor city for one with 190k for $500.00
Found one 10 minutes away for $800.00 SCA cond unknown but says it runs from a totaled 1990 E series
Or pick up a Jasper longblock for about $3,000.00.. gota connection on this one.
Would like to keep the truck for another 10 years if possible as frame and underside is solid.
Question on R/R on the H/G's. I was told today that if I am burning oil now 1qt per ~750 miles that if changed out it will cause oil consumption to increase. [img]/ubbthreads/images/graemlins/shocked.gif[/img] Any truth to this? Spoken from a large truck mechanic.
Baffeled in Decatur,
Ron [img]/ubbthreads/images/graemlins/depressed.gif[/img]
Ron
My Photo Gallery
Goldie 1990 F-350 Custom 4x4 C/C DRW conversion. 7.3L Banks non-waste gated turbo, ZF-5 with 4" custom Exhaust complimenting a RDT venturi system, Autometer Pyro and boost 2 gauge pillarpod and your standard compliment of mechanical gauges. Clutch pedal Heim joint mod.
The Beef 1989 F-350 Lariat C/C DRW 7.3L N/A, ZF-5. Clutch pedal heim joint mod. Original price $500.00.
Currently slated for an extreme makeover ground up restoration.
Mater 2007 F-250 Lariat 4x4 6.9L IDI, T-19 trans pushing a 7'6" Western plow. Completely assembled from the tires up!
I got your "Jeep Thing" now it burns when I pee.
Dsl_Dog_Catcher is offline
Old 03-11-2005, 09:06 PM   #2 (permalink)
Re: Bad Head Gaskets...What next
You must have the hook-up on gaskets too. I can't find my prices, but I recall the valley pan being $53 alone. How your r&r-ing the heads for $125 I'd love to know [img]/ubbthreads/images/graemlins/grin.gif[/img]
Neal in MN
2005 F350 4x4 Crew Cab, short bed.
1980 Mercedes 300D
Sold - 1990 F350 [img]/ubbthreads/images/graemlins/frown.gif[/img]
V2Neal is offline
Old 03-11-2005, 09:24 PM   #3 (permalink)
Got a good connection at Napa and he can get them for me at cost. I had thought about rebuilding the current engine till I saw my cost on the masterkit.... $1,828.00 [img]/ubbthreads/images/graemlins/shocked.gif[/img]
Which leave block sleeving and head work up to bout $1,200.00. Found the Jasper option to be kinda enticing. [img]/ubbthreads/images/graemlins/phoney.gif[/img]
On the head R/R, it is just replacing the HG's. Typed out different than I was thinking. I haven't even tried to look that option yet. Have been told NOT cheap for good work on 'em. [img]/ubbthreads/images/graemlins/confused.gif[/img]
Ron
Ron
My Photo Gallery
Old 03-11-2005, 10:17 PM   #4 (permalink)
Hey, if cost is no object, I'd go with the new Jasper out of the options you listed. No worries, full warranty. Yeah.
Fix it and be done with it is my philosophy. That philosophy has cost me some dollars since I bought this truck, but I've never had to worry about any repairs I've done breaking.
I'd like to keep my truck another 10 years, too... but would probably repower with a Cummins or see if DPS could build the IDI to provide the power/torque I want rather than buy a rebuilt standard 7.3 IDI.
Mike
- SOLD: 1991 F-350 XLT crewcab, dually. BTS E4OD. My favorite truck.
- NEW DAILY DRIVER: 2006 Ram 3500 SLT quad cab. 5.9L Cummins, 6-speed manual transmission, nav system, Jake brake. No mods, now or ever. 100% satisfied.
Mike Lewis is offline
Old 03-11-2005, 11:11 PM   #5 (permalink)
My Photos: (23)
Question on R/R on the H/G's. I was told today that if I am burning oil now 1qt per ~750 miles that if changed out it will cause oil consumption to increase. Any truth to this?
I'd be curious as to what science he would exhibit to explain what surely is a myth.
- Mel
1983 F-250HD 4X4 The Moose Truck - Moose Pump, DPS Injectors, Hypermax Turbo, GV 7spd., 3.54 Gears, Moose Air, RDT, Dual Stacks, 35"tires. My Album 55MPH at 1400 RPM. 19MPG Avg.
1993 F-350 CC DRW The Lady Moose - Hypermax Turbo, GV 9spd w/Double OD. 4.10's. Dual Exhaust, custom trim, turned up 6.9 fuel system, Lucky Flywheel.
1987 Bronco The Moosestang 1987 Bronco Diesel 6.9L C6 4X4 with 3.54 gears, 2" body lift.
HeadGasket/Turbo Article
A BOOB man! Visit EZBoard.com and search for IDI.
agnem is offline
Old 03-11-2005, 11:21 PM   #6 (permalink)
My Photos: (9)
Well, I’m not even gonna pretend that Roadmaster has as good a reputation as Jasper. But I tell ya what, I’m one of 3 on this board that I know of (I’m sure there are others) running Roadmaster iron. All I can say is, super easy to deal with, and a great motor so far. 12k turnkey miles. That sewing machine lights right off even when its 5° outside, and it doesn’t seem to burn a drop of oil between oil changes. Good power, and a good marbley clatter. It’s accepted the turbo and water injection quite nicely also.
My opinion is they are a good company out of the great state of Texas, and long block for $2,309.30. That’s the best price I’ve seen. Worth a look anyhow.
RoadMaster
-Rob
92 F350 XLT Crew Cab, 4x4, 7.3 IDI, 5 speed ZF
W/G Banks Sidewinder Whistle On By , Splash Water Methanol Injection
LUK SMF conversion, Remanufactured 7.3 1/27/04 Hear it start
They should have called it the compression stroke
The Blizzard
The Blizzard Super Sized
Super Sized and Smokin
350camper is offline
Old 03-11-2005, 11:22 PM   #7 (permalink)
MEl,
I asked why he thought that. He said that the new increase in pressure would cause the consumption increase.
HHHHUUUUUUHHHH?
I am hoping that for now, I can wing it on HG replacement. When I charged things up today, it was pissing up a storm. Didn't need to borrow the little ones baby powder. [img]/ubbthreads/images/graemlins/rolleyes.gif[/img]
Ron
Ron
My Photo Gallery
