Old 07-07-2005, 12:31 AM   #1 (permalink)
Ball Joints and bearing race removal
I've got everything torn apart, I just can't figure out how to actually remove the ball joints.
Also, how do you remove bearing races and the spindle bearing that are pressed in?
One last thing is there is a little bearing right at the cap over the automatic hubs, mine is broken. Autozone and Napa can't seem to replace it. Any ideas on a source?
Thanks for the help
-Nate
94 F-250 IDI Factory Turbo. E4OD Auto 205k miles.
Banks Transcommmand. ATS 3" Exhaust. ATS Intercooler. Pre-Charged Coolant Filter.
Gagues: Autometer Pyro, Trans & Tranfer Case, rear diff, boost, 3 water temps, oil pressure.
Sams Club Goodyear Wrangler AT/D2 265/75R16LRE
02 X 4x4, 56K miles stock. Michelin LTX M/S 265/75R16LRE. 30MM Ford Sway Bar. DP Tuner 40T/80T/80E/120R. AIH delete, AFE Stage 2 PG7, MBRP 4" Turbo back, Coolant Filter, Baldwin Transfilter, lots of gauges, mag-hytec diff covers (front hits and is a waste of money) maybe some other stuff.
Needs springs or airbags or something.
nateccie is offline
Old 07-07-2005, 01:04 AM   #2 (permalink)
Re: Ball Joints and bearing race removal
I cut mine out with a torch if your careful it works fine. If you can get it off take it to a shop, a local alignment shop did mine. They have a press to put the new balls in and they can press out the old one too. After you get all done you will probably need to get a realingment anyway, they will probably cut you a deal if they can do the alignment, mine didn't charge me anything.
Greg
1988 F250 7.3 diesel 4x4 auto C6 now ZF5
1990 F250 7.3 diesel 4x4 auto E4OD. now ZF5
1992 F250 7.3 diesel 4x4 ZF5
Greg77 is offline
Old 07-07-2005, 10:32 AM   #3 (permalink)
I overstated a little bit. I got everything apart except the ball joints are still holding the ?yoke? onto the axle. I removed the cotter pin from the top ball joint and took off that nut that the pin was holding. There's a nut on the bottom ball joint that isn't moving too...
nateccie is offline
Old 07-07-2005, 11:43 AM   #4 (permalink)
You need to get one of those fork looking things. You wedge it inbetween the spindle and the axel deal and bang it with a hammer and it'll all pop right off. I tried banging it all with a hammer the first time i did mine and it wouldn't budge, i had about given up until i went to a local autoparts place and found a fork big enough, then i went home and tried and bam, came right off. I could've saved a whole day if someone had mentioned that. I got mine from pepboys, they were the only ones that had the fork with a wide enough gap.
Eric
Ford 1992 E-350, 6,900 lbs.
Dodge 1997 Ram 3500
Ford 2005 F-350
yaric008 is offline
Old 07-07-2005, 11:56 AM   #5 (permalink)
I don't know if you have any auto parts places that rent tools nearby, or a general rental business, but they may have a ball joint press for rent. There are a couple of places locally here that rent them. They look like a big C-clamp on steroids, and work pretty well at pushing the ball joints out, and new ones in.
Wheel bearing races can be driven out with a drift punch and a hammer. The new ones should be installed with a brass punch if possible to protect the bearing surface.
I have not removed the spindle bearings before, so can't help with that.
Good luck! Not a fun job, but can be done.
Bill
1993 F250 4x4, Extended cab with a 7.3L IDI, 3.55 axles, 5-speed manual, Hypermax Turbo, 3.5" Hypermax exhaust, No soup bowl, a K&N filter, and a newly installed RDT. Hoping for an intercooler install soon. 152,000+ miles and counting.
bgfire is offline
Old 07-07-2005, 02:02 PM   #6 (permalink)
Spindle bearings are a slip fit. They will come right off if you pull on them.
Dave
2004 F-350. Standard Cab, 4X4, 6.0 with Torqshift, 3.73 w/LS. <font color="red">(((XM))) Satellite Radio.</font> Lo Jack, 6608 lbs wet. Born on 8/4/2003. Engine 07/23/2003. 3" Lift. Grover Air Horns!!!
http://community.webshots.com/album/85108545NlXNsD
1993 F-350 4X4 7.3 IDI with 5 spd. Gone now.
1976 Kenworth C-500 with Detroit Diesel 8V92TA with 3 spd Jake, SQHD's and RTO 12513 10 Wheel Dump Truck. Sold.
dbennett48 is offline
Old 07-13-2005, 05:13 PM   #7 (permalink)
I'm a little late, but I just replaced mine a couple weeks ago.
The traditional way to remove the tapered shaft on the ball joints is to hammer the round shoulder holding the tapered stud (the end with the big nut). Ford's manual says so too. I tried for an afternoon but the secret was to hit well and hit firm. This required removing the dust cover and cranking the steering all the way to get a good swing (big hammer). With that both steering knuckles came out.
The cylindrical fit in the other end is a little tougher. A clamp, or press would be best. I used a good quality big clamp with a brass fine thread, with well placed hits to help it out. It is hard but can be done.
For bearing races (the cone), carefully punch them back in, I like to go 180* across and then 90* degrees. Don't get them ****ed, hold the big punch firmly so you stay on the thin edge.
Bruce
87 6.9 F350 dually, T19, now 4.10, regular cab, 160"wb, ramair, 3" exhaust, flatbed, w/ flatbed gooseneck GVCW 27K
mndorf is offline
