Old 09-04-2006, 11:23 AM   #1 (permalink)
xtremefreerider's Avatar
Banks, Oil Pressure, Fan Clutch
Pulled motor last night and I have a few questions....Does anyone know where I can find a step by step manual for the install of a Banks Sidewinder? I got mine out but don't know how its going back in but I can tell you it won't be in the order it came out.....The oil line for that turbo is tied into the old sending unit for the oil pressure, correct? Then the sending unit is on the turbo..correct? Can I replace that SU with one from Auto-meter to work with my oil pressure gauge on the pillar?
Lastly, anyone know what size the fan clutch nut is? I can't find the proper tool around here and since I live in the boonies I tried everything withing a 1.5h drive with no luck so its time to improvise, or if all else fails, get a bigger hammer....thanks
-Brian
1990 F-350 REG CAB LONG BED, 7.3 IDI, '95 ZF-5, LUK CLUTCH W/ SINGLE MASS FLYWHEEL, 87 BW 1356 T-case, FOUR GAUGE PILLAR MOUNT W/ AUTOMETER BOOST, PYRO, OIL PRESSURE AND WATER TEMP, BANKS SIDEWINDER WASTEGATED TURBO, EAGLE 16.5" WHEELS, 4 INCH SUPERLIFT, 35/12.5/16.5 BFG Muds, Eaton Rear End (7/05), Blown Motor (9/05), New motor, trans and t-case (9/06), Custom 5" straight pipe (8/07) - Pics coming soon....odometer rolled for the second time...although I don't have the correct spedo gear and the spedo/odo didn't work for 15-20k miles
MY PHOTOS
The Goat - 2008 Dodge 2500 CC LB 4x4, 6.7L Cummins w/ 6sp manual. So far bone stock except a leveling kit
xtremefreerider is offline
Old 09-04-2006, 11:28 AM   #2 (permalink)
Re: Banks, Oil Pressure, Fan Clutch
I have used a hammer and large drift to knock off the fan clutch.
try ebay for banks info or banks.
1987 F250 dually 7.3 banks sidewinder C-6 GV overdrive 3.55 lots of factory eliminated mods
i/e rear hung single battery, re engineered fuel system, no more tank switch, electric holley blue pump, return style regulator, #8 fuel line feed and return, both tanks, Amsoil 5w30HDD with full flow / bypass filters, Amsoil of course.
Evans coolant and Amsoil conical air filter. last oil drain 2003 65k ago. I add about 8qt per year with filter change. rear main likes to leak parked only.
IDIABUSE is offline
Old 09-04-2006, 01:58 PM   #3 (permalink)
cdnsarguy's Avatar
My Photos: (66)
I had that info in my garage but have misplaced it, so I will measure the 2 tools at the shop this week.....
Proud Canadian BOOB man too!!
cdnsarguy is offline
Old 09-04-2006, 06:43 PM   #4 (permalink)
Found a large cresent wrench, a ratchet strap and a log splitter (w/ a 4cyl wisconsin and a ram from a D8) the clutch came right off. I also went digging through the box of stuff from the PO that I got 4 years ago and found the Banks manual along with every reciept down to $4 air fittings.
-Brian
MY PHOTOS
Old 09-04-2006, 11:21 PM   #5 (permalink)
Sounds like your on the way with the finds. Good luck and post back with any questions. Plenty of help here.... [img]/ubbthreads/images/graemlins/smokin.gif[/img]
icanfixall is offline
