Re: Banks Stinger
Personally, I'd leave the muffler off. These trucks aren't loud straight piped. As for the air filter, what does it look like? Take it off and take it with you to a parts store. Tell them to find the closest match.
--motor/trans sold--
2000 VW Jetta TDI = 48+mpg
1997 Dodge 3500: 2WD Cab & Chassis, 12V Cummins, 47RE Automatic, Dana 80, 194,000mi. Parting out.
1989 12V VE Cummins out of Chevy C60? at the machine shop...going into the Ford.
Member of Indiana Air National Guard 122FW MXS
