Old 07-11-2005, 10:06 PM   #1 (permalink)
Battery Suggestions/Questions?
I'm getting ready to replace all of my cables and both batteries, and I'm wondering where to get the best "bang for the buck" when it comes to the batteries. Right now, it has two tired Bosch 850 CCA in it. Also, what is the best way to guard against corrosion? Thanks.
1993 F-250 Supercab, 7.3L(IDI), E4OD
heaphus is offline
Old 07-11-2005, 10:30 PM   #2 (permalink)
Re: Battery Suggestions/Questions?
Atta Boy, Your my kinda of guy!
You will get the most for your hard earned dollar at Sams Club,
under $50 will buy a 850CCA Excide, I believe it is over 1000CA.
This battery has proven itself in Minnesota winters, I replace them every 3 years, in the fall, not because they need to be replaced, but I don't want any "issues" when it is below 0
Get the "Group 65", it is made for the Ford battery box, perfect fit.
As far as the corrision,
Don't over fill, (I never need to add).
'93 F-250 IDI, 4x4, K&N, no soup bowl, stock, with 265,XXX miles 5 speed, 3.55, kind of new LUK clutch, runs great, starts great, it is great. The truck is getting old.
BuilderBob is offline
Old 07-11-2005, 10:41 PM   #3 (permalink)
Buying new batteries and cables is one of the best ways to guard against corrosion. Keeping the battery terminals and cable ends clean is the best way to avoid corrosion. Should you somehow get corrosion, baking soda sprinkled on the terminals with some warm water will disolve any corrosion. Tim
'94 F250, 4X4, 7.3, E40D, 4.10, 126K
tim94f250 is offline
Old 07-11-2005, 11:37 PM   #4 (permalink)
rawpower's Avatar
And in a tight spot, a carbonated drink like Coke will work... leaves a little bit of a sticky residue though, so wash it off afterwards.
1993 Ford F350 7.3L Turbo Diesel ZF S5-42, Divorced TS NP205, OEM locker/welded 2.5 ton Rockwells, 46" Michelin XML's, and some stuff too.
http://www.supermotors.org/users/RAW_POWER
rawpower is offline
Old 07-12-2005, 12:49 AM   #5 (permalink)
My Photos: (17)
I use Exide Orbital Spiral Wound AGMs. Absoultly NO corrosion and they function as a deep cycle but with only half(500)the cycles of a real(1000)deep cycle. They are kinda spendy but they really spin the engine. Baja
<font color="red">1987 F350, 4X4, Crew Cab, DRW, w/'91 7.3 TURBO-CHARGED BY ATS, no-Wastegate(Turbo rebuilt by me 7/2005)</font>, <font color="blue">E4OD Auto, Aux Trans Cooler w/12" fan, w/Baumann Programable Trans Computer-12/05</font>, Rebuilt Injection Pump-2/03, Electric Fuel Pump, Coolant Filter, "BajaGringo Block Drains, 5-Row Radiator Core-9/04, 2 New Plastic Fuel Tanks w/new Sending Units/Pickups, Fuel Filler Neck Mods, Air Ram Intake, Air-Lift SuperDuty AirBags with Smart Lift Auto Leveling-7/2005 <font color="blue">Link to Photo of "OkieGringo Idler Pulley"</font>
<font color="red">Link to GP Controller Diagram</font> <font color="blue">Link to "Electric Fuel Pump Wiring Diagram"</font>
OkieGringo is offline
Old 07-12-2005, 08:43 AM   #6 (permalink)
i'm running little felt washers between that sit under the terminal end on the cable. seems to help a little with corrosion. they should be available at any hardware store.
1999.5 Ford F-250. Extended cab/long bed. 4R100
K&N, DFuser 18K power module, MBRP 4" exhaust, and a little extra boost. I have bigger plans when time will allow.
Deceased:
1989 F-250: 7.3 IDI, propane injection, C6 (mikes trick shift rebuild) single cab, LWB, 4x4, ranchhand rear bumper, 600W sony sound system, and the nifty little holder for my cowboy hat on the headliner... RIP old faithful
westbound is offline
Old 07-12-2005, 09:15 AM   #7 (permalink)
FWIW...
Several months ago, I had all 42(?) 12V batteries in a 40KVA UPS replaced at the office. I asked the installers what they were slathering on the terminals during re-assembly and they both said "No-Lox grease" (NOT silicon... very dino looking/smelling)????? I asked and they said it had some sort chemical properties that inhibited corrosion (there was absolutely ZERO corrosion on the old batteries and to date, none on the new batteries).
I was basically thinking it would be nice to have something like that and they gave me the rest (75-80% full) of the can. I've been using it on ALL electrical connections and have NO corrosion on anything it's been applied to so far...
'92 F250 4x4 Reg.Cab LB/7.3L IDI w/ PS filter&RotellaT @ 178K
ZF w/ Mobile1 syn. ATF
TTB&10.25FF with4.10s
B&W+Tenkosha"Voyager"+Putnam ClassV
PRE-scratched & dented Jeep Hauler
Rented Mule
CaverDave is offline
Old 07-12-2005, 09:27 AM   #8 (permalink)
The best product I've found is copper gasket sealer. It is conductive and it doesn't harden for a long, long time. Coat your battery terminals and cable ends once a year. Works for me.
Old 07-12-2005, 10:44 AM   #9 (permalink)
Gibson's Avatar
not sure what gets rid of corrosion but anti-sieze keeps it from corroding over. the only bad thing is your ahnds will get dirty each time you tuoch the termanals and cable ends. its worked for over a year now......Gibson
D.T.Gibson
1.830.203.1460
new newer rig: '05 greyish/balckish Ford F-350 XLT Lariat, Crew Cab, 6.0L PowerStroke, Fx4, Leather and all the electric goodies besides a moon roof, auto trans, 3:73's, leveling kit. SCT Looney Tune stacked with Edge Juice with Attitude, and 4" turbo back exhaust. 91K.... blew HPOP and headgaskets. In shop for now. maybe by the 8th ill have her back with new long block! sweet!
newer rig: late '99 Red Ford F-350 PowerStroke, 4x4, CC, 4r100 Auto Trans, 3:73's, Stage Coach Conversion, 4" DP to 5" up to 6" stack, aFe Stage II intake, DP Tuner 4pos chip, dFUSER oil crossover line, 10K mod, AIC controller, '06 18" King Ranch Wheels. 225K.
new rig: CUMMINS POWERED '95 F-350 XLT, crew cab, Blue & white, ZF5-speed, 4x4 with auto locking hubs, 4:10 gears, 283K miles, 3" DP to 5" exhaust, Auto Meter A-pillar 3-gauge pod with EGT, Water temp and oil pressure.
Gibson is offline
Old 07-13-2005, 02:21 AM   #10 (permalink)
i just use some grease on the ends, it is redish brown, not sure what it is, whatever was in an old grease gun laying around, kind of like a multipurpose bearing grease. I clean terminals and apply new grease everytime i disconnect the batts to service electric parts, no corrossion so far, i just smear it on, not using very much. Also i just recently repainted my battery trays, pressure washed them, then sanded, then hit it with a rust kill primer, then finished with some some rust oleum rust tuff paint. Everything is still holding up just fine.
--Ryan
91 f-350, dually, 7.3 diesel. 2wd, 4.10 gears LS. E4OD. New injectors, lift pump, and fuel filter at current 85,000 miles. Autometer pyro and fuel turned up. 3" exhaust with walker "btm" muffler
http://community.webshots.com/user/olivera_149
olivera149 is offline
Old 07-13-2005, 02:23 AM   #11 (permalink)
A lot of wholesale electrical supply houses sell no lox. stuff is great. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
1994 F350 crew cab Dually 2 Wheel Drive 7.3 IDI, E4OD,factory turbo. just purchased april 2003, did rebuild ( rings and bearings )may 2003, Ready to start adding extras!!!
comp486 is offline
Old 07-13-2005, 04:24 PM   #12 (permalink)
Thanks guys!
heaphus is offline
» Sponsor Links
»Garage Storage and Cabinets
