battery terminal help - Diesel Forum - TheDieselStop.com
Old 01-29-2013, 09:55 AM   #1 (permalink)
bsurb's Avatar
I have to replace my passenger side battery, but the screws that are into the terminals are like sunk into the terminals. walmart said they couldnt get it with a wrench because they didnt want to break a post or something.
here is a picture.... any suggestions?
bsurb is offline   Reply With Quote
Old 01-29-2013, 10:02 AM   #2 (permalink)
Term3's Avatar
Just take a small wood chisel and shave down the lead until you have full access to the nut. Or drill a hole down into the clamp so can take a pair of side cutters and cut the clamp off.
Term3 is offline   Reply With Quote
Old 01-29-2013, 11:38 AM   #3 (permalink)
bsurb's Avatar
I twisted and pulled both terminals off... I have thick wire and if I buy brand new terminals, doi just cut the wires and put them into the new terminals?
Old 01-29-2013, 12:37 PM   #4 (permalink)
Phil G.'s Avatar
BTW, I would not suggest replacing only one battery, the other will take the new one down. My buddy ignored my advice and replaced 1 only last summer on his 03 7.3L and we just replaced both of them this week..... If the other one is reasonable, it can be sold to recoup a few bucks.
2007 F350 SRW 6.0L Auto, 3.73LS, 172"WB 4x4.Viper VX790 Alarm/RS w/motion sensor, WD pillar Guages,Touchscreen CarPC in custom console w/ AutoEnginuity,Parrot Handsfree Blueooth,2 Infinity Amps (611A & 7541A) Alpine PXA-H701 Processor, Infinity 6010CS 6.5" components up front and Infiniti Kappa 62.7i 6.5" 2-way in rear doors, 12" RD Sonance Sub, Ranger CB w/ dual Wilson 2000's, 100gal polished alum fuel tank, 5th hitch, Rapid Hitch aluminum TT hitch, Bremen full glass running boards, painted mirrors, grille, door handles,valence,wiper arms,mount. Westin Bull Bar w/LightForce 140's
Phil G. is offline   Reply With Quote
Old 01-29-2013, 12:49 PM   #5 (permalink)
If you cut the cable get the military type terminal and use cable lugs instead of the clamp on style terminal.
Alvin Mitchell
Pablo Montana
1983 F250 4X4 4.10 gears 4 speed dana 50 center/44 outers Dana 70 rear
Mitchalvin is offline   Reply With Quote
Old 01-29-2013, 02:02 PM   #6 (permalink)
bsurb's Avatar
I got the terminals that you screw down the thick wire and then I take the ground and put s connector on it and screw that down with the other screw. I think these are the universal military ones.
Old 01-29-2013, 03:57 PM   #7 (permalink)
The military style have a bolt through both sides one is smaller and clamps the terminal on the post, the second is larger and holds the lugs to the terminal.
Alvin Mitchell
Pablo Montana
Old 01-29-2013, 04:24 PM   #8 (permalink)
bsurb's Avatar
is this right? and the ground goes into the yellow connector.. then place on the terminal.
Old 01-30-2013, 06:31 AM   #9 (permalink)
mf7lakes's Avatar
why can't you take that small wire and squish it in with the big one?
1993 (new in 10/'92) F350 crew cab XL, 7.3L IDI, 4X4, 5sp manual,C5 axle 4.10, 78,000 mi.
mf7lakes is offline   Reply With Quote
