Amongst the many other changes being considered for my baby. Whats the overall opinion of the feasibility of changing out the diffs from the 4.10's I have to 3.55s? Fairly difficult/impractical or a moderatly difficult swap and what'll be needed.
The truck is primarily used as a daily commuter with occasional 5-6 K tows (maily to hunting camp).
What'll the overall impact to me be?
94.5 F250HD Ext Cab XLT 4x4
Ford Factory IDI Turbo w/ATS Outlet/Downpipe upgrade with 4" exhaust system (working good)
ATS step 1 upgraded E4OD (only 'til it dies)
Sterling (Ford)10.25 4.10 R-diff,
Dana 50 4.10 F-diff
ISSPRO EV Pyro, Boost & Tranny temp gauges
Pillar Mount
'93 F-250 IDI, 4x4, K&N, no soup bowl, stock, with 265,XXX miles 5 speed, 3.55, kind of new LUK clutch, runs great, starts great, it is great. The truck is getting old.
Just find a complete rearend in a salvage yard with the ratio you want. Drop drive shaft, probably change out brake cables and if your fussy, new U bolts, depending on shape of old ones. The last one we did was $350.00 for the rearend. Depending on salvage yard may be up to $500.00 so check around. You may have to redo brakes and a couple of other small things things but it's a couple hour job and not real expensive. Just be sure to check the free play or backlash in your replacement axle to make sure it's good. Just turn a wheel on one side back and forth and feel how far it turns before catching another gear. If you have a four wheel drive it get's a little more involved, still doable just takes more time and a little more money.
Greg
1988 F250 7.3 diesel 4x4 auto C6 now ZF5
1990 F250 7.3 diesel 4x4 auto E4OD. now ZF5
1992 F250 7.3 diesel 4x4 ZF5
I'm not sure what year diffs. you can use. As for the tranny, you will need to change the speedometer gear. But, the main reason for my reply is to tell you to never re-use axle u-bolts. The same reason you don't re-use head bolts is why you don't re-use axle u-bolts. They stretch after being torqued the first time you use them. Just ask the guy where you buy your suspension parts if you can re-use the u-bolts. Tim
Personally I'd swap to something like a 14-bolt. The 10.25 ford rears we have are junk. They look big but I've never seen one live long that was abused. Seen alot go down because the wheel bearings weren't getting oil and seized up. A 14-bolt is alot stronger and cheaper, and you won't have a problem finding one at all.
--motor/trans sold--
2000 VW Jetta TDI = 48+mpg
1997 Dodge 3500: 2WD Cab & Chassis, 12V Cummins, 47RE Automatic, Dana 80, 194,000mi. Parting out.
1989 12V VE Cummins out of Chevy C60? at the machine shop...going into the Ford.
got to say I have never heard that one, alot of PSD's making 400 RWHP with this same axle and no problems from "abuse" [img]/ubbthreads/images/graemlins/shrug.gif[/img]
any year axle from '93-97 will work as long as it has the speed sensor in the pumpkin. where are you located???
as for the front end and year D50 will work, all you will have to do is swap out the differential, it bolts to the back of the left TTB.
Diesel Rod
Formerly Diesel Rod.
A '97 F250 with 295K miles, 90 LED's and 5" stacks, among other things....
A '96 F250 Reg cab with 210K miles, Needs to go away. PM me. '86 359 Peterbilt SHORT HOOD. The ongoing "project" it aint pretty but its got a 425 air to air Cat motor .....13 speed Eaton. Corvette Dash, 17 gauges, 8" black stacks, 63" flat top---> 36" sitting here waiting for paint. 1.305 Million Miles.
I don't know what I am doing, I just know I don't have time to do it.
If you've got a Dana 44 front diff. there are lots of them around. There seem to be more 410's than 355"s and now there are lots of people switching so look around and check a few different places. If you have a Dana 50 those are harder to come by and more expensive. As far as years 1983 thru 1997 should all work.
Greg
i had a '95 4x4 stroker that had '87 axles (3:55's) and then we swapped a '94 4x4 stroker axles in its place (4:10). then we traded the 4:10 ring and pinions for a set of 3:55's form a 93 4x4.
so we ened up with:
'95 stroker got '94 axles and '93 3:55's
'94 stroker got '87 axles and '94 3:55's
'93 turbo diesel got '87 4:10's
its all switched around. i feel srry for the guys who got the truck and didnt realize the year modle of the axles/gears... we traded all the trucks a few months ago.... Gibson
D.T.Gibson
1.830.203.1460
new newer rig: '05 greyish/balckish Ford F-350 XLT Lariat, Crew Cab, 6.0L PowerStroke, Fx4, Leather and all the electric goodies besides a moon roof, auto trans, 3:73's, leveling kit. SCT Looney Tune stacked with Edge Juice with Attitude, and 4" turbo back exhaust. 91K.... blew HPOP and headgaskets. In shop for now. maybe by the 8th ill have her back with new long block! sweet!
newer rig: late '99 Red Ford F-350 PowerStroke, 4x4, CC, 4r100 Auto Trans, 3:73's, Stage Coach Conversion, 4" DP to 5" up to 6" stack, aFe Stage II intake, DP Tuner 4pos chip, dFUSER oil crossover line, 10K mod, AIC controller, '06 18" King Ranch Wheels. 225K.
new rig: CUMMINS POWERED '95 F-350 XLT, crew cab, Blue & white, ZF5-speed, 4x4 with auto locking hubs, 4:10 gears, 283K miles, 3" DP to 5" exhaust, Auto Meter A-pillar 3-gauge pod with EGT, Water temp and oil pressure.
I'm in Iraq, but the rig is in Graham Washington where I'll be in December.
As my profile shows I've checked the driveline as much as possible, but my assumption was that the "50" cast into the front diff meant Dana 50. The rear I read off a the data tag and cross referenced (if my memory doesn't fail me).
Are all Dana diff's of a certain # set at x.xx gearing? In other words are Dana 50 all set at 4.55 etc.... Is there a reference chart about this?
What's this about the 14 bolt pattern?
Myplan is for the 3.55 to get me more mileage on the daily commute and still have enough for my light-medium duty towing.
Dana 50 4.10 F-diff
Pillar Mount
no not all D50's were set to a certain gear ratio. 3:55's were the standard, 4:10's were optional.
The rear is a Sterling 10.25, the early fords were Dana 70's up till I think '92??????
You will be pretty much stuck using a Sterling unless you want to do some interesting fab work, as your speedo has a sensor in the rear diff that it NEEDS to work.
gears out of a Sterling 10.5 will work, these were used in the SD trucks, 3:55's, 4:10's (3:73's and 4:33's were optional) and D50 up front is pretty easy to get gears for if your gunna go new.
Diesel Rod
14 bolt is a GM corporate axle [img]/ubbthreads/images/graemlins/shrug.gif[/img] If I was swapping in a non-matching axle, I'd at least use a Dana axle. Ford vans use Danas with the VSS sensor in the housing. I don't know what the width difference is.
