hi yall,
i got a problem with my belt squeeling when i first take off, then it gets fainter but it is still there. i know it is the belt cause if i spray armor all on it it quits, but it starts back up as the engine gets hot. It is a new belt. Maybe i need to clean the pulleys? Brake cleaner? It does not effect preformance, but sounds like the truck is about to fall apart with all the squeeling.
thanks for your input
Kevin
(mine) 94 7.3 IDI non-turbo XL 350 super cab long bed
autojet y pipe and a used p-stroke exhaust on the end of it 24xxxx miles, amsoil bypass, coolant filter
(dads) 02 350 7.3 powerstroke crew cab 4x4 ESOF
mods: itp in tank/prepump, 4 inch exhaust, ats housing, western diesel gauges, 6.0 transmission cooler, 6.0 Banks "technicooler" intercooler 150 bucks , coolant filter, "OEIS", b&w 5th wheel companion
18xxxx miles my gallery
WHY THE HELL SHOULD I HAVE TO PUSH 1 FOR ENGLISH? H O N D A - How Odd No Damn Acceleration
Did your old belt squeal? If so, could be a weak tensioner. Maybe double-check the belt size. A larger belt would be looser, possibly causing squeal. I've had tiny rocks/sand get stuck in the V grooves and make noise. Otherwise, maybe an accessary not rotating freely, dragging on the belt? BTW-I would clean the pulleys. I usually use an old toothbrush on mine before putting the belt on.
92 F350 XLT Crewcab dually, 204K miles ATS turbo, 3 inch exhaust, DPS IP & Stage 1 injectors, Holly Red pump, K&N, E40D, aux cooler, A-pillar guages, 410 limited-slip rear, Rancho 9000s, towing package, full running boards, mud flaps, 94' Ford (Alcoa) aluminum wheels, Predator camper shell, 200 watts of Sony/Boston Acoustics! Complete engine rebuild at 176k miles. Ford reman E4OD at 204k miles.
2001 Komfort 26FS My Truck
hi yall,
Kevin
Armor All is not good on belts, it is silicone and will make the belt slip. Try spraying some parts cleaner on the belt to clean the Armor All off and see if you can tighen the belt a little more.
Check your tensioner and pulleys for condition......... you should be at the end of tension release to slip the new belt on......... How is the vacuum pump and pulley.......
yes the old one did squeel, but i did have to clean the tensioner cause it was hard to turn, so i soaked it with wd40 and then sprayed it with some silicone. and it was fine, but still squeeks. the vaccuum pump is recently new, but i'll check, so the general concences is take take the belt off and see if any components don't turn freely?
thanks, kevin
thanks for all of your help, my tensioner is weak. ill be ordering a new one.
thanks again,
kevin
