Belt tensioner collapsed, bolt threading directions?
Hi all,
she stopped today after major noise, cause: Belt tensioner seems to have collapsed and bent out, fan has crushed the pulley, belt wound around main pulley, strangling the engine.. To get the tensioner out, the plastic pulley right below it must out first, but the torx bolt seems stuck... I guess it is threaded anti clockwise, so I must turn it clockwise to loosen, am I right? (The pulley runs anticlockwise as far as I can see) Want to be sure befor I any more force on it.
Thanks.
1994 E350 Custom Line 7.3IDI, E4OD, 2WD Limited Slip, 4wheel ABS, K&N air filter, 3rd owner, 130K miles on the clock
ACCN - American Car Club of Norway Member no. 263314 My Photo Gallery
Re: Belt tensioner collapsed, bolt threading directions?
Visit my gallery for the picture........
Thanks Pete, that did the trick. As always you've got the answer [img]/ubbthreads/images/graemlins/smile.gif[/img]
Inside the tensioner there is an aluminium "tower" and at the end a steel plate is attached, holding the whole cr.. togheter. The plate was simply broken right off and all disintegrated.. Hope the new one will hold longer.
Ray.
Just keep an eye on it. Ive had to replace mine within 2 years of replacing with a new one. The Ford Stealership parts guy just shrugged his shoulder when I told him when I asked about warranty. But with mine I had noticed a longer start and dimming of lights when I decided to check my belts and had noticed a odd shift in the tensoner seating. I took it out after determineing that it was bolted correctly and found it to be nearly ready to bust. I installed the new one and truck started quicker and the lights became brighter...I am planning on it busting again so I am keeping an eye on it....
Also make sure you have the right v belt when you replace it. I think one is an inch diffrence than the other. Also there is a marking on the tensoner when the belt is installed that tells you if it is correct....
David and his Ford truck with a little motor and a big idea......
Ford F-350 Dually Crew Cab 5-Sp 7.3 IDI Centurion Conversion. No mods, rebilt IP and replaced injectors. Used as personal driver and pulling my RV camper.
Planned upgrades are a new and better turbo and larger exhaust pipes than the 21/2s that are already under the rig/ would like a 6 spd tranny but dont know if that is a feasable or smart investment yet.
1993 Dodge 3/4 ton Van Conversion 318CI
1978 Dodge Magnum XE T-top Classic 4BBl 400CI (Honeymoon Car)
1965 Dodge Polara 4 DR 383CI
Got the tensioner and new belt on yesterday, fumbled some to get the belt on because it was so tight... but at last I got it on by sliding it on the idler pulley as the last one. Very tight, but the arrow on the tensioner is right on the beginning(left) of the wear marking so I guess the belt is correct.
Ray, hang onto all the old parts. Ford warrants the tensioners for 1 year. I had to replace mine in a parking lot once and still had all the old parts when my "new one" snapped less than a year later. I took all the parts from the first one that broke and saved myself $100.
Why they build those things so cheap I'll never know. A huge steel spring in a potmetal housing. I added a steel washer to the front plate and so far (2 years) no trouble.
Doc,
'94 F350, Crew Cab, 7.3IDI, 4X4, E4OD, 220K
God Bless Texas, Lone Star beer, and great Mexican food.
