Best fuel conditioner? - Page 2 - Diesel Forum - TheDieselStop.com
post #16 of 23 (permalink) Old 01-14-2011, 01:53 PM
Sootsme's Avatar
I've gotten excellent results from Ford's additive (easier starts, less smoke, more power & better fuel mileage) ~$8.00 bottle treats 125 gallons. Warm & cold weather formulas. However, I'm sorta new at this, so does anyone concur or disagree? still learning...
Sootsme is offline
post #17 of 23 (permalink) Old 03-05-2011, 11:43 PM
Kevin 007's Avatar
HEY YOU FELLOW CANADIANS!!!!
Hey fellow Canadians!! Im not sure how many of you know of this product yet, but...Im just starting to get into Milligan Diesel Fuel conditioner. Its "grown" in Foam Lake Saskatchewan. A pure canola based product.
After a double dose in two tanks, im starting to notice an increase in fuel economy. And from what I hear...the lubricity of the product is great!!
its a 1000:1 additive. I only add a couple ounces per tank; making it cheaper than Stanadyne, and about the same as Howes and Power Service.
I will be switching from Howes to Milligan for good... Proud to support a small town Canadian prarie product
1984 F-250 6.9, T-19, BW1345, BB code injectors, low mileage, manual Beru Glow Plugs, D70 rear end. solid truck.
1985 Toyota Landcruiser BJ60, 5 bearing cam 3B 4cyl diesel, H55F trans. Best rig I have ever owned.
1981 Honda Trail 110.
Kevin 007 is offline
post #18 of 23 (permalink) Old 03-06-2011, 12:00 AM
Caveman52's Avatar
I use Walmart Tech 2000 Marine 2-cycle oil. It costs about $11.00 a gallon. I put in about a quart everytime I fill up. I generally fill up at the same place everytime too. It's been working great, but recently I have the advance on the IP "sticking" a little. I gave it a double does last time I filled up, hoping the "sticking" was related to moisture or something environmental. We've had some crazy weather the past few weeks (rain/snow, 5 degrees to 50 degrees).
1994 F-250 Super Cab 7.3 Liter IDI Turbo Diesel 3.55 gears, 5-speed, 4x4, Hypermax Turbo
Auto Meter Boost & Temperature Gauges, Hewitt Pyromter
3-1/2 Straight Pipe, Bucket Seats, Rust & Red in Color
Caveman52 is offline
post #19 of 23 (permalink) Old 03-06-2011, 12:07 AM
chuckster57's Avatar
I cleared my sticking advance by filling the filter with SeaFoam. Warmed the engine up and then swapped the fuel out with the SeaFoam. Ran it for about 2-3 minutes, shut off and let it sit for an hour or two. Then started and idled for about 3 minutes, then took it to the freeway and drive it like I stole it!! no problems anymore
Train Horns:
PM please not visitor message
chuckster57 is offline
post #20 of 23 (permalink) Old 03-06-2011, 10:18 AM
Caveman52's Avatar
chuckster 57,
I might have to try that, Thanks.
post #21 of 23 (permalink) Old 03-07-2011, 06:40 AM
paintingman's Avatar
I stopped using the two stroke oil it may be good for injector lube but it made my truck hard to start. the fuel additives with cetane makes the truck start faster. Here's some test results
In Order Of Performance:
1) 2% REG SoyPower biodiesel
HFRR 221, 415 micron improvement.
50:1 ratio of baseline fuel to 100% biodiesel
66.56 oz. of 100% biodiesel per 26 gallons of diesel fuel
Price: market value
2)Opti-Lube XPD
Multi-purpose + anti-gel
cetane improver, demulsifier
HFRR 317, 319 micron improvement.
256:1 ratio
13 oz/tank
$4.35/tank
3)FPPF RV, Bus, SUV Diesel/Gas fuel treatment
Gas and Diesel
cetane improver, emulsifier
HFRR 439, 197 micron improvement
640:1 ratio
5.2 oz/tank
$2.60/tank
4)Opti-Lube Summer Blend
Multi-purpose
demulsifier
HFRR 447, 189 micron improvement
3000:1 ratio
1.11 oz/tank
$0.68/tank
5)Opti-Lube Winter Blend
Muti-purpose + anti-gel
cetane improver
HFRR 461, 175 micron improvement
512:1 ratio
6.5 oz/tank
$3.65/tank
6)Schaeffer Diesel Treat 2000
cetane improver, emulsifier, bio-diesel compatible
HFRR 470, 166 micron improvement
1000:1 ratio
3.32 oz/tank
$1.87/tank
7)Super Tech Outboard 2-cycle TC-W3 engine oil
Unconventional (Not ULSD compliant, may damage 2007 or newer systems)
HFRR 474, 162 micron improvement
200:1 ratio
16.64 oz/tank
$1.09/tank
8)Stanadyne Lubricity Formula
Lubricity Only
demulsifier, 5% bio-diesel compatible, alcohol free
HFRR 479, 157 micron improvement
1000:1 ratio
3.32 oz/tank
$1.00/tank
9)Amsoil Diesel Concentrate
Multi-purpose
demulsifier, bio-diesel compatible, alcohol free
HFRR 488, 148 micron improvement
640:1 ratio
5.2 oz/tank
$2.16/tank
10)Power Service Diesel Kleen + Cetane Boost
Multi-purpose
Cetane improver, bio-diesel compatible, alcohol free
HFRR 575, 61 micron improvement
400:1 ratio
8.32 oz/tank
$1.58/tank
11)Howe’s Meaner Power Kleaner
Multi-purpose
Alcohol free
HFRR 586, 50 micron improvement
1000:1 ratio
3.32 oz/tank
$1.36/tank
12)Stanadyne Performance Formula
cetane improver, demulsifier, 5% bio-diesel compatible, alcohol free
HFRR 603, 33 micron improvement
480:1 ratio
6.9 oz/tank
$4.35/tank
13)Used Motor Oil, Shell Rotella T 15w40, 5,000 miles used.
Unconventional (Not ULSD compliant, may damage systems)
HFRR 634, 2 micron improvement
200:1 ratio
16.64 oz/tank
price: market value
14)Lucas Upper Cylinder Lubricant
Gas or diesel
HFRR 641, 5 microns worse than baseline (statistically insignificant change)
427:1 ratio
7.8 oz/tank
$2.65/tank
15)B1000 Diesel Fuel Conditioner by Milligan Biotech
Multi-purpose, canola oil based additive
HFRR 644, 8 microns worse than baseline (statistically insignificant change)
1000:1 ratio
3.32 oz/tank
$2.67/tank
16)FPPF Lubricity Plus Fuel Power
Emulsifier, alcohol free
HFRR 675, 39 microns worse than baseline fuel
1000:1 ratio
3.32 oz/tank
$1.12/tank
17)Marvel Mystery Oil
Gas, oil and Diesel fuel additive (NOT ULSD compliant, may damage 2007 and newer systems)
HFRR 678, 42 microns worse than baseline fuel.
320:1 ratio
10.4 oz/tank
$3.22/tank
18)ValvTect Diesel Guard HeavyDuty/Marine Diesel Fuel Additive
Multi-purpose
Cetane improver, emulsifier, alcohol free
HFRR 696, 60 microns worse than baseline fuel
1000:1 ratio
3.32 oz/tank
$2.38/tank
19)Primrose Power Blend 2003
Multi-purpose
Cetane boost, bio-diesel compatible, emulsifier
HFRR 711, 75 microns worse than baseline
1066:1 ratio
3.12 oz/tank
$1.39/tank
CONCLUSIONS:
Products 1 through 4 were able to improve the unadditized fuel to an HFRR score of 460 or better. This meets the most strict requirements requested by the Engine Manufacturers Association.
Products 1 through 9 were able to improve the unadditized fuel to an HFRR score of 520 or better, meeting the U.S. diesel fuel requirements for maximum wear scar in a commercially available diesel fuel.
Products 16 through 19 were found to cause the fuel/additive blend to perform worse than the baseline fuel. The cause for this is speculative. This is not unprecedented in HFRR testing and can be caused by alcohol or other components in the additives. Further investigation into the possibilities behind these poor results will investigated.
Any additive testing within +/- 20 microns of the baseline fuel could be considered to have no significant change. The repeatability of this test allows for a +/- 20 micron variability to be considered insignificant.
CREDITS:
This study would not have been possible without the participation of all companies involved and dieselplace.com. A special Thank You to all of the dieselplace.com members who generously donated toward this study and waited longer than they should have for the results. You folks are the best. Arlen Spicer, organizer.
"03 2500 HD, Kennedy Mega Filter, STOCK PAPER AIR FILTER, Oilguard Bypass, Primrose, Baldwin Oil Filter, ARE Camper Shell, Line X Liner, Westin Nerf Bars.
Offline
_________________________
2004 F250 6.0 PSD every day work truck
Jotto desk / laptop / printer for giving estimates
3000 watt inverter keeps drill batteries charged
4" tubo back MBRP cool duals
CFM+ intake elbow / Airaid cold air intake
SCT X3 from innovative diesel
Coolant Filter / Amsoil by-pass system
ATS Intercooler
Fluidampr / 200 amp alternator
ARP head bolts / Black onyx head gaskets
185cc Injectors 70hp+ / stock turbo
stage 1 fuel lines / cross over with fixed orifice
58 volt FIMC mod from swamps diesel
Airdog 2 with in tank fuel module upgrade Mag-Hytec Diff. and trans. covers
Aluminum degas tank
paintingman is offline
post #22 of 23 (permalink) Old 06-01-2015, 10:13 AM
The top best fuel conditioner is the Prolab DBF-4. Tried every snake oil on the market and the only one that realy works is this DBF-4.
2,2 million km and no problems!
Zeus55 is offline
post #23 of 23 (permalink) Old 06-01-2015, 11:40 AM
I too use the tcw-3 two stroke oil for extra lubrication. My engine quieted considerably when I started using it.
94 F350 Dually 2wd,4:10,E40D,R&D pump, sticks, and 3"turbo downpipes,Dynomax 3" exhaust,Gear vendors, 24000 trans cooler,
Johnnybgood is offline
