I want to do new injectors and I am not sure what the best one to use is,I have a 94 with the IDI turbo engine.
Thanks,Tim
99 F-250 EXT Cab 4x4 Powerstroke Diablo Delta chip,4" turbo back exhaust, all necessary gauges!
94 f-250 ext cab 4x4 7.3 IDI turbo SOLD!!
94 SVT Cobra #1668
90 f 250 7.3 sold
93 11 sec. mustang 5.0 sold
94 3.8Mustang vert driver sold
80 cj-78 mud toy sold
97 5.0 explorer
While your replacing the injectors why not buy the modified injection pump from Ken at DPS also. The return line kit will need to be replaced because they will leak when you try to reuse them. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
I've got DPS's Stage ones in my 94, I havent gotten to drive it much since the install though. Havent noticed much difference yet, but like I said havent gotten to drive it much. Once they are done salting the road I will be driving it more.
1994 F-350 4x4 IDI Turbo Reg Cab XLT ATS Mods, BTS Trans & Converter,8' Western Pro.......
1997 F-350 4x4 PSD E-4OD,Crew Cab XLT..........
1999 F-350 4x4 PSD 4R-100, SC, LB, Lariat, Western 8.5 MVP...........
I'm looking for some good factory replacement units. Not extremely interested in putting in performance injectors and pump. Would like the truck to just run and start better. What are the stage 1 injectors?
1994 Ford F250 extended cab long box Factory Turbo Diesel with E4OD.
94 SVT Cobra #1668
90 f 250 7.3 sold
97 5.0 explorer
