Old 03-07-2007, 10:57 AM   #1 (permalink)
My Photos: (15)
Best location for trans temp sensor?
I was hoping to get a few oppinions on the best location for a transmission fluid temp sensor with the E40D. Previous owner had one tapped into one of the lines heading up to the front of the truck. Wasen't working so I removed it at the time.
Seems like there must be a port on the case that would be better?
Mike
89' F350 Crew Cab 4x4 E40D 4.10:1 Early Banks Turbo No More Trans Command - Transgo "TUGGER" 5" Stacks Bronco 33gal Tank
Runboys Pics
Runboy is offline
Old 03-07-2007, 11:46 AM   #2 (permalink)
Re: Best location for trans temp sensor?
There is a port on the driver's side of the trans, towards the front, just above the pan. There's a black hex head plug from the factory. Remove it and install the probe.
Casey_1 is offline
Old 03-07-2007, 02:10 PM   #3 (permalink)
That is where I have mine. I have since heard that this is not the best choice? It was recomended to place it in the pan or the line to the cooler.
1990 F-350 Dually 4X4 CC Rebuilt Turbo and NEW 7.3L DAS engine, rebuilt rear diff, Reman E4OD Stage 1 injectors Stage 1 pump Baumann recal kit and TDC for E4OD dead trans again...
2004 F-350 4X4 CC 6.0 PSD
2004 Wilderness 320dbhs TT
DSBlack is offline
Old 03-08-2007, 04:26 PM   #4 (permalink)
Everyone has their opinion on the best location. My opinion is the test port is the best place.
Casey_1 is offline
Old 03-08-2007, 07:23 PM   #5 (permalink)
Mine is in the "test port" and I have many-o-miles on it without any trouble.
icanfixall is offline
Old 03-09-2007, 01:54 AM   #6 (permalink)
My Photos: (15)
Only downfall I can think of to having it in the case is that you may be getting more of a "case temp" reading than "trans fluid temp".
Any thoughts?
I would prefer it in the case rather than dangling around in the middle of the cooler line, unless the verdict suggests that the temp reading is that much more accurate.
Mike
Runboys Pics
Runboy is offline
Old 03-09-2007, 01:58 PM   #7 (permalink)
I have been asking a lot of questions, I have had a lot of trans issues, and never had the trans hot. I have the gauge at the port mentioned.
I am not a trans guy. I know very little about them. So I am by no means an expert.
I was told that the flow of the fluid is low in that area, and if the temp increases rapidly, then falls off, you may not see that in this port? I do not know if they are correct or not. I have not moved mine from this port, but I do plan to.
DSBlack is offline
Old 03-09-2007, 04:18 PM   #8 (permalink)
I am a trans guy. I know a lot about them. People that I work with consider me a trans expert among transmission people, and transmissions are what I've worked on for almost 20 years.
True, but so what? Is that what you want to know? Do you want to know the temperature of the transmission or the maximum temperature the fluid sees for a short time when the torque converter unlocks under load? I like to know the overall trans temp, not the transient spike when the converter unlocks. If I were to have multiple trans gauges I'd have the secondary one in the line, but in my not so humble opinion the port is the right place to put the sensor.
But you don't have to believe some anonymous person posting on the internet. I could be all wet, but I don't think so. [img]/ubbthreads/images/graemlins/grin.gif[/img]
Casey_1 is offline
Old 03-09-2007, 08:40 PM   #9 (permalink)
well was the port put there for this reason or not?
1987 F350 4 Door 6.9IDI 5Spd Banks Turbo Dually -1986 F250 Reg Cab 6.9IDI 4spd 4X4 Dually-1988 F250 Reg Cab 7.3IDI C6-1985 F250 Ext Cab 7.6 DT466 10spd
http://community.webshots.com/user/MyDTpickup
INTERNATIONALDIESELPOWER
MyDTpickup is offline
Old 03-09-2007, 09:12 PM   #10 (permalink)
It was not put there to measure temperature. It was put there to measure line pressure. The Ford shop manual refers to this port for trans diagnostics. The tech screws a pressure gauge into the port and runs a series of pressure checks.
Casey_1 is offline
Old 03-10-2007, 01:21 PM   #11 (permalink)
I did not mean to offend anyone. I have learned a lot from everyone here. Just passing on some info about what I heard/learned after loosing 4 trans in 40,000 and never having one overheat on the gauge.
DSBlack is offline
Old 03-10-2007, 01:34 PM   #12 (permalink)
The best place would be in the line exiting the transmission heading to the cooler ( front Line) because most of the heat generated in the transmission is in the torque converter. This line comes directly from the converter out to the cooler and then back to the rear lube circuit. Locating the temp probe here will allow you to see if your converter is slipping which is usually the first thing to overheat the fluid. IMO this is the only place to locate the trans temp gauge and am about to put mine there. I am a Ford certified diesel tech as well as an instructor in a local technical institute and this is the only place that makes sense to me.
94 F250 S/C 4x4 7.3 lt IDI factory turbo E4OD and 4.10 soon to be limited slip, bone stock with triple gauge pod on the a pillar
swervn69 is offline
