Old 11-22-2007, 03:25 PM   #1 (permalink)
Best static timing for 7.3 IDI
When timing a diesels you can play a little with the static timing to best suit your power/fuel efficiency needs. At what degrees is the best compromise of both?
Abrooks is offline
Old 11-22-2007, 03:46 PM   #2 (permalink)
Re: Best static timing for 7.3 IDI
when refering to "degrees" static time how does one measure this with simple hand tools? When adjusting dynamic timing on 7.3 IDI diesels where is the sweet spot where everything runs smoothly?
Abrooks is offline
Old 11-24-2007, 02:24 AM   #3 (permalink)
cdnsarguy's Avatar
My Photos: (74)
This info from Ziggster's files....
You need to line up the scribe mark on the pump flange with the scribe mark on the pump gear housing. That's essentially it to start with. Hopefully the gear housing hasn't been removed, 'cause if it has it is possible the pump timing gear has been moved, and it is very difficult(but not impossible) to get it back to the right spot.
On the housing that's mounted on the top front of the engine where the pump bolts into, There is a small line about 1/4" long stamped into the rear/upper face of the housing just where the pump would mate to the housing. Likewise, on the pump almost at exactly the same spot on the flange of the pump where it bolts to the housing is a similar line scribed into onto the top of the pump flange.
The idea is that when you put the pump into the housing on the engine, and if you have those two marks lined up such that the almost form one 1/2" Long line, then the timing will be close enough that the engine should start and run. This is known as static timing.
Dynamic timing via luminosity is done where a probe is put into the cylinder, and actually sees the light from the explosion of the fuel, and the timing is set accordingly.
Some of us set the timing by "ear". This comes from some experimentation and experience.
I like mine so that when the engine is cold, as the cold advance is on, the engine rattles pretty loud, but once the cold advance drops off, then the rattle smooths out and the engine is much more quiet. If you have it too advanced, then it makes that loud rattle all the time, often accompanied by lots of black smoke, and if too retarded, will sound kinda flat most of the time, lack power, and often not smoke at all, or may even smoke greyish/whitish(unburned fuel).
When you are standing at the front of the truck facing the engine, if you turn the pump couterclockwise(top of the pump to the passenger side) you'll be advancing the timing, and obviously clockwise will retard the timing.
Zigg
If you line up the gear cover and pump top center lines you will be able to start it.
The marks on the pump to housing are only accurate if it is the original pump from the factory. Turning the injection pump 1/16" to either side (measured at the pump to housing flange marks) that's about 4 deg. Turning IP to pax side is advancing timing, to drivers side is retarding, engine off for all adjustments and tighten nuts on IP before start.
Pete
6.9IDI ( Navistar method ): 6-7 degrees BTDC
7.3 NA: 8-9 degree BTDC*
7.3 IDI Turbo: 8-9 degrees BTDC*
Diesel Don
Proud Canadian BOOB man too!!
cdnsarguy is offline
Old 11-28-2007, 03:17 PM   #4 (permalink)
My Photos: (23)
Where do you live? Maybe your close to someone like me who can time it properly for you.
- Mel
1983 F-250HD 4X4 The Moose Truck - Moose Pump, DPS Injectors, Hypermax Turbo, GV 7spd., 3.54 Gears, Moose Air, RDT, Dual Stacks, 35"tires. My Album 55MPH at 1400 RPM. 19MPG Avg.
1993 F-350 CC DRW The Lady Moose - Hypermax Turbo, GV 9spd w/Double OD. 4.10's. Dual Exhaust, custom trim, turned up 6.9 fuel system, Lucky Flywheel.
1987 Bronco The Moosestang 1987 Bronco Diesel 6.9L C6 4X4 with 3.54 gears, 2" body lift.
HeadGasket/Turbo Article
A BOOB man! Visit EZBoard.com and search for IDI.
agnem is offline
Old 01-02-2008, 01:14 PM   #5 (permalink)
I live north of Toronto, ontario, Canada
Abrooks is offline
Old 01-02-2008, 02:52 PM   #6 (permalink)
cdnsarguy's Avatar
My Photos: (74)
Put that info in your my stuff profile under location......do some truck info too........
» Sponsor Links
»Garage Storage and Cabinets
