Does anyone know if it is possible to change to the type of wiper arms that have the hose IN the arm itself? I'd love to lose the center-cowl squirter and get a better arm assembly on my windshield.
Thanks,
Mike
- SOLD: 1991 F-350 XLT crewcab, dually. BTS E4OD. My favorite truck.
- NEW DAILY DRIVER: 2006 Ram 3500 SLT quad cab. 5.9L Cummins, 6-speed manual transmission, nav system, Jake brake. No mods, now or ever. 100% satisfied.
What is it about the current wiper arms that you do not like? I find that traveling over 75 MPH, that the arms kind of levitate and do not wipe the windshield. Aside from that, I think they work fine, even the cowl mounted squirters. Tim
Aren't you not supposed to use rain-x in conjunction with wipers?
Best wipers i have ever seen come from costco. They have a teflon blade on them and they last for about 6 months, as compared with about 1 week for normal wipers for me.
One thing to check and it may require some retrofiting. The 92 thru 97 series put two squirters in the front cowl piece. I have an extra one here and that may bolt on the 87 thru 91 or may have to make new holes to install it in the 87 thru 91's.
1988 F250 7.3 diesel 4x4 auto C6 now ZF5
1990 F250 7.3 diesel 4x4 auto E4OD. now ZF5
1992 F250 7.3 diesel 4x4 ZF5
I looked at those wipers i got, they are made by trico. If all else fails, give those a try. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
My 91 E350 has the squirters in the arms.
__________________ 1991 Ford PL Custom Ambulance Type III 7.3L Diesel. Photo Here Pioneer AM/FM/XM/CD Stereo. Code 3 lightbar, Whelen Strobes and flasher lights. Whelen flood lights on front, rear and sides. There bright enough to turn darkness into daylight. Siren with several tones plus electronic airhorn and PA. Custom 3" exhaust from manifolds back with a Gibson Superflow Muffler [img]/ubbthreads/images/graemlins/grin.gif[/img]. Dual alternators and dual sets of batteries. If I need a jumpstart all I do is push a button. On spot tire chains that install and de-install themselves at the flip of a switch. Also has air compressor on board along with suction unit and O2 system.
1972 Cadillac Hightop Ambulance by Superior Lucky if I get 10MPG
Not that bad, The fluid hookup on the wiper arm are 1/8" and you just need to buy a little plastic reducer and your good to go. The wiper blades are the same for the truck and the van.
The thing that bugs me about the 93', is that you can't squirt and then wipe. You wipe then squirt, or at best get both at once. Ford never should have taken away the ability to squirt only. Nothing like grinding dry crap into your glass before getting lubrication.
i agree !!!!!!!!!!!!!!!!! [img]/ubbthreads/images/graemlins/eek.gif[/img]
