and does it cycle or keep heating like if i leave it on for a few days will it keep heating or does it cycle to a certain temp range?
88 F-250 body,550 rear frame setup, 7.3 idi, 3:73 dana 80 rear, srw, dana 50 front, heavy duty leaf springs, back up camera, 20$ wallyworld fog lamps, class 5 bumper hitch welded to frame and gusseted, brush guard with front mount hitch, 32" steering tires all around, ac power converter,jeep bucket seats, deezee runningboards (cab only),cobra 29 cb w/ 102" whip, 2 trucklight worklights on front stake pocket each side,high lift jack behind seat, toolbox for the junk, visor, running lights, 6600 lbs with all my junk
its either 1350 watts, or 1500----dont remember which
I thought it was 1200W...?? Who knows. Divide wattage by 120V...10A.
I do know that it wouldn't be as high as 1500W. That would be tripping alot of people's breakers by drawing 15A for long periods.
Also- it is constantly on no matter what.
--motor/trans sold--
2000 VW Jetta TDI = 48+mpg
1997 Dodge 3500: 2WD Cab & Chassis, 12V Cummins, 47RE Automatic, Dana 80, 194,000mi. Parting out.
1989 12V VE Cummins out of Chevy C60? at the machine shop...going into the Ford.
I actually thought it was 1000 watts. Regardless, as long as it's plugged in, it's heating. No thermostat or cycling. As stated above, you can put a timer on it to come on before you intend to drive it. I did this once until I fixed my glowplugs. 2 hours heating prior to starting is plenty. Plus it's nice to have instant heat out of the heater (inside the cab).
92 F350 XLT Crewcab dually, 204K miles ATS turbo, 3 inch exhaust, DPS IP & Stage 1 injectors, Holly Red pump, K&N, E40D, aux cooler, A-pillar guages, 410 limited-slip rear, Rancho 9000s, towing package, full running boards, mud flaps, 94' Ford (Alcoa) aluminum wheels, Predator camper shell, 200 watts of Sony/Boston Acoustics! Complete engine rebuild at 176k miles. Ford reman E4OD at 204k miles.
2001 Komfort 26FS My Truck
All you would have to do is buy a short extension cord and hack it in half and connect it. The list having 420 in stock. I thought about getting a few for my farm tractors (the ones I might use in the morning, stager warm them so I don't trip the breaker.
1999 E-350 Cub Wagon, 7.3L Power Stroke, E4OD, 3.55
1990 E-350 Club Wagon, 7.3L IDI, E4OD, 3.54LS
1983 F-150 2x4, 4.9L, C-6 w/GV-OD, 3.55 Farm pickup
1981 C-8000, 3208 CAT, RT-6510, Rockwell SSHD Tandems (Swap)
1977 K100C, NTC-350, RT-1110, Tandem
1977 Transtar II, NTC-290, RT-9509 Single
1977 Transtar II, Formula 290, RT0-9513, Tandem
1974 C-750, 391CID, Clark 5 speed, Eaton 2 speed
Good find Kaliburz. I might have to order one of those.
1990 Ford F-350 Crew Cab Dually 2WD
7.3 Liter Non-Turbo
Repainted 10/2005
ATS billet transmission installed with the "5 star clutch system" 7/2007---LOVE IT!!!!!
Basically Stock except for 3.5"exhaust
Rotella oil since new in 1990. http://rides.webshots.com/album/347448034IlTAPm
cloutierthedj- good to see another member from Indiana on board. There seems to be alot of us. Where are you from, if you don't mind me asking?
I found a gizmo that plugs in between the heater cord and the extension cord that turns on a 34 degrees and turns off at 45 degrees. Sure is sucks electricity when "on" but since I'm having rad leaks and haven't gotten a 'round tuit' and am just using straight water, a higher electric bill is better than a busted block. I had arortic aneurism surgery Dec. 3rd and can't lift that damn rad out to get 'er fixed AGAIN. It's been hard enough just cutting up all the dang trees and branches that fell during the ice storm three days after I got home from hospital. OkieGringo
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: OkieGringo</div><div class="ubbcode-body">I found a gizmo that plugs in between the heater cord and the extension cord that turns on a 34 degrees and turns off at 45 degrees. Sure is sucks electricity when "on" but since I'm having rad leaks and haven't gotten a 'round tuit' and am just using straight water, a higher electric bill is better than a busted block. I had arortic aneurism surgery Dec. 3rd and can't lift that damn rad out to get 'er fixed AGAIN. It's been hard enough just cutting up all the dang trees and branches that fell during the ice storm three days after I got home from hospital. OkieGringo </div></div>
I had one of those too, for my tractors long time ago. I'm not sure what it was rated, but I think I destroyed mine quick. Air temp showed like 28F and the thing still wouldn't turn on. Thought it was block heater, so I by passed that temp device.... heater started right up. I think it might have worked once or twice before it went TU.
I even tried some of those conventional timers, slide the on/off for time. But I think they were not high enough in rating. I destroyed one of those also. At the time, I think I only found a 15amp one (1800/1825 watt). It would turn, but when it got to the spot to 'turn on', just wasn't enough 'uph' to turn. [img]/forums/images/%%GRAEMLIN_URL%%/confused.gif[/img]
I had a bad head gasket and was running water for a few weeks in winter. Added some water every morning. Keeping it plugged in will keep the block from freezing, but the heater core won't be protected. Had to bypass the split heater core and drive around with no heat until I got a another truck.
Never just use water......always use coolant with at least the minimum requirement for your area/time of year. $10 a week the weakest strength of A/F is way cheaper than a $400 RAD.
