Block heater ? - Diesel Forum - TheDieselStop.com
Old 01-16-2013, 11:14 AM   #1 (permalink)
Block heater ?
I need some help.
Truck 1990 7.3 IDI, E40D, 2WD, 105k Original miles
Problem
Cold start= lots and lots of smoke
Last night I plugged in the block heater, this am started fast NO SMOKE at all
What do I need to fix??
BCMBLM is offline   Reply With Quote
Old 01-16-2013, 11:35 AM   #2 (permalink)
Snotzalot's Avatar
How long does your Wait To Start light stay on?
This time of the year cold starts produce lots of smoke.
You need to plug it in for at lest 2 hours every morning.
Regards,
Paul - Pocono Mtns. USA
02 E350 15 Passenger Cream Puff, 64,000 Miles, 5.4L Gasser
'90 E350 7.3L Ex-Ambulance High Top 420K Miles, No Turbo, Stock Stock stock, No ELC! (Extended Life Coolant) & 10 Oz. Bars Stop Leak. 10 wonderful cool years using Freeze12 without any AC system modifications. Retired 11/8/2011 with blown trans.
7.3L Alternator Belt Idler Photos note, the belt number I listed is wrong and the correct belt, i.e. non cog and non stretch is NLA.
Snotzalot is offline   Reply With Quote
Old 01-16-2013, 05:42 PM   #3 (permalink)
AUcobra94's Avatar
If you smell fuel at idle you probably need to change your return lines. Atleast that is what mine needed. Starts much better with alot less smoke.
92 F-250 7.3 IDI (non-turbo), E4OD, 3:55, 4x4, Banks Turbo coming soon.
AUcobra94 is offline   Reply With Quote
Old 01-17-2013, 11:51 AM   #4 (permalink)
Cold engines will smoke until the chambers come up to temp. If you plug it in the chambers start at a warmer temp so it will not smoke as much.
Alvin Mitchell
Pablo Montana
1983 F250 4X4 4.10 gears 4 speed dana 50 center/44 outers Dana 70 rear
Mitchalvin is offline   Reply With Quote
