Old 01-04-2008, 01:50 AM   #16 (permalink)
Re: block heater replacement
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Snotzalot</div><div class="ubbcode-body">If your cooling system is bled, you ain't got no bubbles in the system. </div></div>
Just repeating what he said. I guess he wanted to err on the side of caution so that they wouldn't have to replace any 'burned out ones'.
1999 E-350 Cub Wagon, 7.3L Power Stroke, E4OD, 3.55
1990 E-350 Club Wagon, 7.3L IDI, E4OD, 3.54LS
1983 F-150 2x4, 4.9L, C-6 w/GV-OD, 3.55 Farm pickup
1981 C-8000, 3208 CAT, RT-6510, Rockwell SSHD Tandems (Swap)
1977 K100C, NTC-350, RT-1110, Tandem
1977 Transtar II, NTC-290, RT-9509 Single
1977 Transtar II, Formula 290, RT0-9513, Tandem
1974 C-750, 391CID, Clark 5 speed, Eaton 2 speed
Kaliburz is offline
Old 01-08-2008, 01:14 PM   #17 (permalink)
My Photos: (17)
The heater cord has a strange shape where it connects to the heater. Ford Stealership wanted $55.00 just for the cord!!! I found exact heater and cord at NAPA for $35.00 part # 605-3137. I have the element right here and the inside butterfly nut WILL NOT fall off inside, the screw has been "peened". Okiegringo
<font color="red">1987 F350, 4X4, Crew Cab, DRW, w/'91 7.3 TURBO-CHARGED BY ATS, no-Wastegate(Turbo rebuilt by me 7/2005)</font>, <font color="blue">E4OD Auto, Aux Trans Cooler w/12" fan, w/Baumann Programable Trans Computer-12/05</font>, Rebuilt Injection Pump-2/03, Electric Fuel Pump, Coolant Filter, "BajaGringo Block Drains, 5-Row Radiator Core-9/04, 2 New Plastic Fuel Tanks w/new Sending Units/Pickups, Fuel Filler Neck Mods, Air Ram Intake, Air-Lift SuperDuty AirBags with Smart Lift Auto Leveling-7/2005 <font color="blue">Link to Photo of "OkieGringo Idler Pulley"</font>
<font color="red">Link to GP Controller Diagram</font> <font color="blue">Link to "Electric Fuel Pump Wiring Diagram"</font>
OkieGringo is offline
Old 01-08-2008, 07:50 PM   #18 (permalink)
asauer's Avatar
Send a message via MSN to asauer Send a message via Skype™ to asauer
OkieGringo- That's what I was talking about. It's the same mushroomed end as rubber freeze plugs have. You've got to really try to get the halves apart- you'll strip out the screw head first, unless you ground off the end, but that's irrelevant when it's installed in the block...
--motor/trans sold--
2000 VW Jetta TDI = 48+mpg
1997 Dodge 3500: 2WD Cab & Chassis, 12V Cummins, 47RE Automatic, Dana 80, 194,000mi. Parting out.
1989 12V VE Cummins out of Chevy C60? at the machine shop...going into the Ford.
Member of Indiana Air National Guard 122FW MXS
asauer is offline
Old 01-09-2008, 02:04 AM   #19 (permalink)
The shape of my buddies 7.3L IDI heater cord was bean/kidney shaped with the three holes. Plugged right in.
I replaced another trucks cord (Cummins NTC 290) and it was the more common out there. Round plug w/ 3 holes held on by a retaining lock (screwed on type). That cord cost me $18.00 for 6 feet (granted, I get a nice discount at the local parts place....) Ebay had cords for the $18-25 range.
Kaliburz is offline
» Sponsor Links
»Garage Storage and Cabinets
