I know you're not supposed to sand off the gasket material when you are reconditioning a block and that the machine shop should do the surfacing because they have exacting tools for it. But do you really think a little light sanding with a random orbital sander with high grit is really going to "round" over some of the surface, warble it just enough to cause a problem with the gasket conncetion?
I'm going to check the block surface with a feeler (0.003 in) and the machine shop's straight edge. What do you think?
1990 F350 7.3L with E40D, non-turbo, pretty much stock
1994 Toyota P/U gasser (22RE)
1987 Nishiki road bike (for the daily grind)
depends- i would if it was alot of old material i would use no courser than 150 grt than when i got almost to metal i'd do the rest by hand with finer grit OR i would soak old with carb, brake clnr or general degreaser and let it soak awhile. i have done it both ways and the soaking w a cleaner and a good scraper works really well.
1999 f350 7.3 6spd; 243k miles no mods
new timing cover
K&N air filter
replaced injectors
new HPOP
new ecm & idm
For prepping gasket surfaces, I always use my 90* die grinder, and run a 3" 3M Roloc disk. Its like a scotch brite pad on crack. There's 4 different abrasive levels. I use the maroon pad, or the brown pad. If you're worried about removing too much material from the deck, then use the green pad. The green pad is for aluminum. Its very soft.
89 F350 SRW Reg Cab 4X4, 3.55:1, ZF-5 w/ LUK single mass, added Banks sidewinder 12-06. So far so good. 17 mpg using B50 bio blend.
94 F350 SRW CC E4OD and factory turbo- currently under construction
Was your engine completely disassembled? If it was you may get away with it after a very thorough cleaning.But if not, the slightest amount of aluminum oxide, and I mean just slight amount that slips thru piston edges or oil gallies will migrate to the sump,thru the pump and take out your main bearings first. 40 years ago believe it or not power tools existed that would obviously do this job much easier, but would earn you a clip in the ear from an old-timer because it wasnt the right way to do it. Use a phenolic or plexiglass scraper, gloves and elbow grease and vacuum often. You obviously feel guilty for it and have your doubts. Your block and head surfaces should show much less than .003 waviness cold for good gasket seat.
03 E350 7.3 psd 15 pass, stock Hi-top with tall doors,245000 mi
00 f250 7.3 psd 2rwd supercab stock,reese electric brake controller,Goodrich rear airbags, 275000 completely reliable miles,
Still starts runs and drives as new
No it shouldn't, like most other diesels, you're allowed up to .006 using a straightedge diagnally, end to end and side to side. You're perfectly safe lightly surfacing the heads and block with fine sandpaper or pad wrapped around a block of wood or whatever, before your final cleaning. Standard practice in any truck shop.
True if the engine is still installed for a field repair,but if I have delivered it to a machine shop I expect an attempt at .0015 and if I cant have that, then an optional gasket for a really bulletproof install. My point being, be aware of what abrasives you use and efforts pay off.
Unless I request that the part be "surfaced", the Machine shop I use will check and if within service limits won't perform that service.
I happen to own my own machinist straight edge, and I do check EVERY head I remove, and so far (12 years) the machine shop and I have used has been in total agreement. He is co-owner of at least 5 land speed records, and has been running that shop for over 30 yrs. shaving a head or block ISN'T a given, and I have put together tons of engines with "regular" gaskets and .005 warp. NOT one has come back in the 35+ yrs I have been doing that, and FWIW I have used fine sandpaper, and a clean rag with brake spray for about the same time, without any failures.
