Old 03-31-2005, 09:59 PM   #1 (permalink)
My Photos: (24)
it blow out
yesterday i was driving my truck and i started to smell something burning. after a few miles i noticed IT WAS ME and i stop the truck. smocke coming out of the front passenger side wheel. i thougth it was the brakes at first but i did them a few month's ago, so i cheked closer and it seems o be inside the hub or the bearings cause when i toke off the cup that cover's the nut inside some grease came out but partially melted.
i never repack the bearings on this truck before could it be a seal got broken?
i will check it this sunday. do i need to replace all the bearing's now or just repakt?
wath about the ones in the back?
thank you, exekiel
Was - 12/92 f350 jasper 7.3L
Is 12/92 f350 - 4.10 open, DRW CC with 5.9l CTD BANKS IC.
Getrag 360
- exekiel coolant filter system (Fleet-guard filter and dca)
- Agnem starting system :-)
more pics
BOOB Man
exekiel69 is offline
Old 03-31-2005, 10:06 PM   #2 (permalink)
dbennett48's Avatar
Re: it blow out
If it were my truck, I would change all of the front bearings. You can start with all new breaings and a good pack job. Get all new seals also. I have had a front bearing seeze on my older truck and it was quite a ride with the right wheel NOT turning at 65 mph. Not good!!
Dave
2004 F-350. Standard Cab, 4X4, 6.0 with Torqshift, 3.73 w/LS. <font color="red">(((XM))) Satellite Radio.</font> Lo Jack, 6608 lbs wet. Born on 8/4/2003. Engine 07/23/2003. 3" Lift. Grover Air Horns!!!
http://community.webshots.com/album/85108545NlXNsD
1993 F-350 4X4 7.3 IDI with 5 spd. Gone now.
1976 Kenworth C-500 with Detroit Diesel 8V92TA with 3 spd Jake, SQHD's and RTO 12513 10 Wheel Dump Truck. Sold.
dbennett48 is offline
Old 03-31-2005, 10:10 PM   #3 (permalink)
cdnsarguy's Avatar
My Photos: (74)
Re: it blow out
Could be a bearing or the calipers causing the heat... I would get a full set of bearings inner/outer and a new seal if that is found to be the problem.
Proud Canadian BOOB man too!!
cdnsarguy is offline
Old 04-01-2005, 07:07 AM   #4 (permalink)
My Photos: (24)
Re: it blow out
hey i know wath you mean, driving at 40 mph on one of my van's the driver side front wheel stop at once and yes IT IS SOMETHING THAT I DO NOT LIKE.
now, is there a part # i need to replace this on my truck, the truck is all stock except for the this i have changed wich are on my sign.
wath price would it be for it?
thank you, exekiel
Getrag 360
more pics
BOOB Man
Old 04-04-2005, 03:59 PM   #5 (permalink)
Re: it blow out
I had exactly the same problem. Turned out it was the caliper. the piston seals were bad and caused the pistons to stay out keeping preasure on the brake. Had to replace the caliper($45-w/ a $45core at car quest)and the rotor. like you i figured it was the brakes and replaced the pads hoping to keep it as cheap as possible. Talked to a mech. he said the calipers go all the time with trucks this old. As a note might as well replace the brake line while youre there.
'90 F250 stock. ZF 5-speed, 4.10 gears, long box extra cab
SyCoRex is offline
Old 04-04-2005, 06:21 PM   #6 (permalink)
My Photos: (24)
Re: it blow out
i replaced the hole set of bearings and seal for both front wheels. total on parts with htemp grease $118.64 on napa.
now i'm planing to replace the seals on the caliper and i want to check the manuals to replace the brake line it dont look bad but you know [img]/ubbthreads/images/graemlins/rolleyes.gif[/img] as you said is old.
wath about the rear wheels, good to do those too or repact them will do?
exekiel
Getrag 360
more pics
BOOB Man
Old 04-04-2005, 11:08 PM   #7 (permalink)
cdnsarguy's Avatar
My Photos: (74)
Re: it blow out
E.......don't even attempt the seal replacement just get rebuilts. It takes knowledge and tools to do the caliper seals and nothing say's it will work after even if done right..
Old 04-05-2005, 05:06 AM   #8 (permalink)
Re: it blow out
I have rebuilt a lot of calipers and wheel cyls and I would not do this in ones garage if you have a shop with shop air and a good parts washer then maybe but there are a few tricks to it and as was mentioned they don't always work afterwards best to go with remans with a warranty
92 F 350 ex cab 2 wheel drive DRW 7.3 IDI ATS turbo 4" straight pipe got my 5" stacks soon to be installed ZF 5 speed 4.11 gears tweaked pump K&N air filter Pulled all its life 329,000k miles engine soon to be overhauled going to put on reman pump and electric lift pump and new turbo thinking of installing IC and propane curious about twin turbos and H20 inj.
81 F 350 4x4 std cab C-6 auto 4.11 gears 351m dead soon to be hopped up 429 had 250,000 on the 351m
90 f 250 4x4 std cab 5 spd 3.55 gears 130,000k
95 C 350 PSD auto 4x4 4.11 gears 96,000k
dieselman1992 is offline
Old 04-05-2005, 07:10 AM   #9 (permalink)
My Photos: (24)
Re: it blow out
ok guy's thank you for the warning. i do brakes all the time but i have never replaced seals. tought it was ease, but as you said i'll get rebuild ones. they are not expensive anyway i readed on another post $45.00 with core.
exekiel
Getrag 360
more pics
BOOB Man
» Sponsor Links
»Garage Storage and Cabinets
