Old 10-07-2006, 09:29 PM   #1 (permalink)
Blower fan speed
My blower moter will only run on high speed, is there a relay or something that controls the speed, and if so where?
Thanks in advance.
My Truck - 1994 F-350 Crewcab 7.3 Factory Turbo
ATS upgraded Turbo Exhaust Housing, 3" Exhaust Outlet Housing and 3" downpipe, 3.5 the rest of the way back.
DPS Stage 1 Injectors
LGF Propane Injection
Pyro,Boost,water temp,trans temp gauges
K&N Filter
Wife's ride- Red, 2003 Excurision, Eddie Bauer, 6.0l 4x4, 63,000 Miles, Bone Stock
31' Salem LE Travel Trailer
My Pics
bsays is offline
Old 10-07-2006, 09:50 PM   #2 (permalink)
Dave Haven's Avatar
My Photos: (16)
Re: Blower fan speed
Your blower speed control resistors may be disconnected or burned out.
The resistor assembly is in the HVAC air plenum. I can't tell you exactly where it is because I haven't had a problem with mine..yet.
Dave Haven is offline
Old 10-07-2006, 10:51 PM   #3 (permalink)
Correct as above^ The resistors I believe are located by the blower motor. You just unplug and remove, and reinstall the new setup.
1994 F-250 XLT Off Road 7.3L IDI Factory Turbo 5 spd Man. 410 gearing. Pump turned all the way up, 14 PSI Boost, 1250 degrees MAX. ATS Outlet/Downpipe upgrade with 4" system. 86,xxx miles.
Is Now CUMMINS Powered. '01 24v with HT Turbo, Injectors, TST Competition and Edge EZ, with FASS.
TurboIHPower is offline
Old 10-08-2006, 12:01 PM   #4 (permalink)
$34 dollars from advance auto parts for blower resistor
robert54 is offline
Old 10-08-2006, 05:51 PM   #5 (permalink)
I got mine from the dealership for $21. It is under the hood next to the blower motor with three wires and a moulded plug.
A.K.A. Sign_man
1988 F-Superduty bucket truck, 7.3 IDI, LuK Clutch, 5 spd, 4.10 rear
http://photos.thedieselstop.com/show...=70062&thumb=1
Phillipmc1268 is offline
Old 10-09-2006, 08:34 AM   #6 (permalink)
Thanks for the info guys, I found the resistors and will change them this week.
K&N Filter
My Pics
bsays is offline
Old 10-09-2006, 09:03 AM   #7 (permalink)
As an afterthought: be sure and check your plug. I have the same problem in my '94. I removed the resistor block and the resistors were actually good. What happened was a bad connection on one of the spade connnections and it caused the connection to burn open. The spade is no longer on the resistor block and my plug is no good also so I have to get the female plug and resistor block to fix my own truck.
Justmike is offline
Old 10-11-2006, 10:40 PM   #8 (permalink)
Agreed, Same thing happened with my dads 97.
Old 10-12-2006, 07:51 AM   #9 (permalink)
I stopped at the Ford store on the way home Tuesday and was utterly amazed. Not only did they have the resistor block, they also had the plug with pigtail. I thought, for sure, they'd have to order the plug if not the resistor block. Turns out, that Ford continued to use this same plug/resistor block on later models. BTW, the plug was almost as expensive as the resistor block. Took me all of about 15 minutes to cut of the burned plug, strip/splice wires, and R&R the resistor block. My replacement steering wheel came yesterday so I will be getting that done soon and won't have a taped up wheel anymore. It'll be nice to have decent leather again.
Justmike is offline
» Sponsor Links
»Garage Storage and Cabinets
