Re: Blowing fuses on starting attempts
In 2000 I installed a System Saver to save the relay/controller etc from coming on every time the truck was started when the coolant temps were below 165*F. The System Saver would only allow the glow plugs to energize under 125*F. This worked well until I started having problems with the truck dying on the hwy and not starting. Puzzling. Yesterday I removed this system and bingo..fuse does not blow anymore and my "Wait to Start" lamp comes on. The switch was shorting out and thus causing the fuse to blow which of course caused the truck to stop (fuel shut off solenoid had no 12V power). It now starts instantly as it always did.
Brian
'91 F-250 XL SC, Schwitzer Blower, LWB, 4x4, LS 3.55's, ZF 5 spd, LUK Rep Set, Most
options except PW/PL, 85000 km, Leer 48" High Boy Cap, Westach
Pyro/Boost Gauges, Hour Meter, Racor water/fuel filter,
Wired for Camper & TT, Fumoto Drain Valve,
Michelin LTX's 235/85R16E A/S
Firestone Ride -Rite
Air Bags and Compressor.
