Blown Fuse
I have a 94 F350 Turbo diesel 4X4 quad cab with E4OD. Does anyone have a wiring diagram. I keep blowing a 10 amp fuse #18 (Electronic shift mode 4wd; speedometer...) It blew this weekend. My speedometer and odometer will not work. Transmission goes into limp mode. Two weeks ago I installed pyrometer, boost, and trans gauges. I removed those to double check I had not wired something wrong. They were working fine and were not effected by the fuse so the problem does not relate to my wiring. I disconnected the electronic sensor on top of the rear diff. (Speed Sensor?) It still blew new fuse with this disconnected. The problem may be under the dash and don't want to remove it again without a schematic.
94 F350 7.3 IDI factory turbo quad cab 4X4 auto North San Diego, Ca
