Blown Head Gasket - Diesel Forum - TheDieselStop.com
post #1 of 13 (permalink) Old 07-24-2010, 02:48 PM Thread Starter
Blown Head Gasket
I got under the truck to find out where some oil was coming from that kept getting on the exhaust and smelling bad. It is on the right rear side at the head gasket seem. I was thinking it was just a valve cover leaking but I could see a slight bubling between the head gasket and the block.
This truck is turning into a money pit. I have put 10K miles on it since I bought it and I have spent several hundred in parts since then trying to keep it running.
So how much are the parts to fix this going to cost? The truck has 180k on it and I am wondering if it is not going to be one thing after another even if I fix this problem. I would expect that I need all the gaskets, thermostat, and glow plugs. Anything else that might need to be replaced that might cause me to have to remove the heads again? I will probably replace both head gaskets since 90% of the work is getting all the crap off the engine and pulling the intake. Should I try to pull the engine out of the truck or leave it in? I don't have a heavy duty hoist or engine stand.
I don't use the truck that much. I probably spend more on up keep than I do on fuel. I guess that is the problem with stuff that sits. Upkeep is the same if you drive it everyday or once a month.
Perry
perryg114 is offline
post #2 of 13 (permalink) Old 07-24-2010, 03:32 PM
chuckster57's Avatar
No hoist and no engine stand will make the job difficult. Do you have any garage rafters that ou can use a block and tackle on? the heads on the IDI's are heavy. Why would you replace the GP's if they are good, or the thermostat for that matter? GP's are right on top so they are a breeze to get to if they go bad.
Head gasket set - about $120.00 includes valve guide seals and valve cover gaskets.
Intake gasket - (valley pan) about $60.00
Antifreeze- Depends on brand and prediluted or not.
YOUR TIME... SO for about $200.00 you could do the job done.
Train Horns:
PM please not visitor message
chuckster57 is offline
post #3 of 13 (permalink) Old 07-24-2010, 04:31 PM
peewee's Avatar
If i remember correctly there is a small hole near the rear of the right head that is used to drain oil & fluid from the valley of the motor. Before I assumed it was a head gasket I would do a thorough cleaning with degreaser and recheck for leaks. Sure would hate to do head gaskets and find out it was the hpop or something else leaking in the valley. By the way oil can leak out this hole, run down the back of the block and into the bell housing of the transmission causing some people to think their rear main seal is leaking
99.5 F350 DRW, AIS Induction system, 4" exhaust, DP F5 tuner, Issopro Gauges, 100 gallon bed tank, 6.0 Trans Cooler, BTS valve body, ATS Turbo housing, Timbrens, 02-04 Headlights, Cree LED headlights, WeatherTech Mats, Homelink, 130,000 miles
peewee is offline
post #4 of 13 (permalink) Old 07-24-2010, 05:04 PM
If your talking PSD motor then you might be right. the IDI doesn't have an HPOP. And yes there is a drain in the valley pan but it's pretty much in the center of the rear.
That's a pretty good indicator of a H/G leaking
Train Horns:
post #5 of 13 (permalink) Old 07-24-2010, 05:16 PM Thread Starter
So where is the best place to get gaskets and whatnot? The Ford stealer is not it. I am in Huntsville, AL.
Perry
post #6 of 13 (permalink) Old 07-24-2010, 05:19 PM
Perry
Got my prices at O'Reillys on-line. AZone should be about the same price.
Vehicle Selection at CSK Auto
AutoZone.com | Get In The Zone!
Train Horns:
post #7 of 13 (permalink) Old 07-24-2010, 08:17 PM
junkrider's Avatar
Send a message via Skype™ to junkrider
I've found that autozone is best for price for about everything I've gotten on my truck.
93 F250 IDI TD 4x4 5 speed ext cab 8' 239K Mods: Facet Duralift fuel pump @ 212K, headlight relay conversion @ 218K, custom fabricated radiator support rebuild @ 218K. rockers/lifters/pushrods @ 214K, new fuel tanks @ 233K, new front axle UJ,BJ,spindle bearings @ 233K, new right front UJ LJ drag link @ 239K, new cab corners (both) and drivers floor drivers cab support @ 239K, new left front right rear spring mount @ 239K.
92 Mazda 626 370K (*** DEAD ***)
13 Focus ST 56K (summer DD)
15 Nissan Frontier 3K
04 Suburban Z71 88K
86 Mustang GT Ragtop 5 speed 250K
73 MG Midget ??K
junkrider is offline
post #8 of 13 (permalink) Old 07-25-2010, 08:32 AM
My Photos: (27)
Depending on how bad it's oozing many times it's fixed by just re-torqueing the heads. Back when these engines were fairly new and more common, retorqueing was done at many truck shops as part of maintainance at about 30,000 miles.
LMJD is offline
post #9 of 13 (permalink) Old 07-25-2010, 02:51 PM Thread Starter
Well I can't even get to the valve cover bolts to even try to get to the head bolts. I would assume the heater box has to come out. I am not sure if the oil that I am seeing is coming from the head gasket. I think the oil is actually coming from the valve cover and leaking down to the head gasket. I do see what looks like bubbles coming out of the oil I am seeing.
Perry
post #10 of 13 (permalink) Old 07-25-2010, 02:55 PM
junkrider's Avatar
Perry
I was able to get to the valve cover bolts on mine with the a/c-heater box in place. But getting the head off may be an issue. The pushrods on cylinder #7 wont come out with the box in place, although you may have success with cutting out some of the plastic, but be very careful because there is a module that can be damaged where a vacuum line enters, right up top next to the head.
I ended up leaving my 2 pushrods on #7 in place when swapping out the lifters and valve seals.
I did not pull my heads.
04 Suburban Z71 88K
73 MG Midget ??K
post #11 of 13 (permalink) Old 07-25-2010, 03:00 PM Thread Starter
I have two issues with removing the engine which is probably the best thing to do. I can buy an engine hoist but most of them are too short to pull the engine out of a 4x4 (another reason not to have a 4x4). I don't have a paved route to my shop so getting it in there is going to be a pain. Hoists or engine stands don't roll on grass. If I recall the engines in these things is about 1000 lbs. I am not in my 20's anymore and climbing on top of a truck and trying to pull heads is probably not something I want to do unless I like being in traction.
Perry
post #12 of 13 (permalink) Old 07-25-2010, 03:19 PM
Perry
The hoist will probably roll on a few sheets of plywood. The IDI engine does weigh in at about 1100 lbs. I have taken the tires off on a 4X4 to make the front end squat enough for the hoist to clear. Pulled a V10 out of a dodge 4X4 with a 4" lift.
Another thing to think about is to "plant" the hoist and then roll the truck backwards as you lift the engine. A good strap across the frame under the tranny will hold it up!
Train Horns:
post #13 of 13 (permalink) Old 07-25-2010, 08:58 PM Thread Starter
I tightened up three of the head bolts near the leak. It leaked some when cold but it seem to stop when hot. It has probably been there a long time and it just so happened that it was in a place that I could see it. For the short run I am going to monitor it and see how it goes.
I may sell it or trade it in on a newer model gasser that is easier to maintain and costs less to maintain. I wish I could find a truck that has been as trouble free as my Ranger.
Perry
