Old 09-04-2008, 12:29 AM   #1 (permalink)
blue holley fuel pump question?
im thinking about getting a blue holley fuel pump,i wondering does it improve the horsepower,does it do any better than the factory one.
superdutydually is offline
Old 09-04-2008, 06:35 AM   #2 (permalink)
cdnsarguy's Avatar
My Photos: (74)
Our IPs require a pump that will provide:
Pressure Rating: 4 lb - 6 lb
Gallons Per Hour: 23
Check out the Holley Blue and Red pump specs..... the red is closest to our requirements. If you want to pump 2-3 times the fuel required per hour around and around that's up to you.
There are some benefits to electrical pumps don't get me wrong...... faster priming of the system makes for easier starts if there are air intrusion problems and new filter installations. However if an electric pump is installed serious consideration should be made to installing a Murphy switch which shuts off the fuel in an accident or on loss of oil pressure.
I have a manual lift pump and so far have never been left on the side of the road. I have replaced 3 pumps in my trucks lifetime......but only because of my preventative maintenance practices.
Holley Electric Fuel Pumps - JEGS
Proud Canadian BOOB man too!!
cdnsarguy is offline
Old 09-04-2008, 09:20 AM   #3 (permalink)
hesutton's Avatar
My Photos: (30)
Plus 1 on what Pete said above. I love my Holley Red and will never go back to a mechanical. You will get ZERO performance gain. It is just a transfer pump, not a perfermance part. The blue pump can provide too much pressure. Get a pressure regulator with it or just go with the red.
Heath
1986 F250HD 4x4 7.3L IDI '95 PSD front clip, '97 bed, T19, D60/10.25 with 3.55's. Rebuilt from the frame up. Banks Turbo, DPS IP & Stage 1's, Isspro TTM, Banks Exhaust, Boost gauge, Pyrometer, Precharged Coolant Filter, Holley Red Pump. 16.5 x 37 x 12.5 Goodyear Wrangler's, Air Horns. 6in lift, Fresh Paint, On-board Air. Revamped Interior. Rhino Liner.
1983 F250 4x4 5.0L with C6. 340,000+ miles.
7.3 Project Pictures
Webshots Project 7.3 Gallery
DYNO YOUR IDI AT THE 2009 RALLY
hesutton is offline
Old 09-04-2008, 10:57 AM   #4 (permalink)
FreightTrain1107's Avatar
My Photos: (6)
Scratch me up another vote for Pete. I used a blue because I had a pile of 'em in the garage, but the red will do just fine.
Get it as close to the tank selector switch as possible and mounted on some sort of a rubber block to keep the meat grinder noise down to a minimum.
I wired it to the circuit that powers the FSS in the injector pump. I used a lighting relay and some 12ga wire back to the pump to avoid any voltage drop even tho the pump only pulls a few amps. I also installed a 7.5A fuse in the power feed as well.
For connections, I used Goodyear fuel injection hose SAE J30R9. AutoZoo sells it for 4 bucks a foot now and it's rated for pretty much everything. (Specs listed on GY's site.) You can identify it by the blue color inside. In fact, ALL the fuel lines on my truck are plumbed with this stuff and it's the best.
You'll love the way the system bleeds out after filter changes. (No need to fill the new filters, and no cranking to get the air out anymore. )
As far as reliability goes, the Holley pump is NOT listed as compatible with diesel, but mine has been in for more than 120K miles and it's still humming along just fine. I put a spare under the seat along with a spare reg back when I put mine in, hopefully it's still under there, lol.
Jared
Jared.
updated sig: '94 F-350 XL, 7.3IDI turbo, ZF S-542, 4X4, SRW, 8ft fisher, utility body w/ lift gate, new(2003) and freshly tweaked IP, boost and pre-turbo pyro, aftermarket AC, Holley blue pump, ATS 3" elbow and DP, straight 3" exhaust. 13lbs at 2700rpm's, if you stand on it.(Not too often or kaBoom) 1150* on the pyro and as LOUD as it wants to be. 240,000 miles and counting. This is just my work truck.
Watch where you park your house..
FreightTrain1107 is online now
» Sponsor Links
»Garage Storage and Cabinets
