Old 12-26-2007, 01:53 AM   #1 (permalink)
Body part interchangeability
I've been wanting to fix my driver's door window for a while now. The glass keeps coming off track when I roll it all the way down. In addition, it could use a new panel. Rather than repairing everything, I've been thinking of throwing on some '93ish doors with the newer panel style. Does anyone know if the newer doors will fit on the '90 body style? Could end up cheaper if I can find them in the junkyards.
1990 F-350, Crewcab, 4x4, 7.3L IDI, C6 tranny conversion
sunray is offline
Old 12-26-2007, 10:00 AM   #2 (permalink)
88beast's Avatar
Re: Body part interchangeability
you need to go preepsd long as its not the psd body it will fit the psd bodies are a little different on body lines not realy noticible and they have diferent vent windows
88 F-250 body,550 rear frame setup, 7.3 idi, 3:73 dana 80 rear, srw, dana 50 front, heavy duty leaf springs, back up camera, 20$ wallyworld fog lamps, class 5 bumper hitch welded to frame and gusseted, brush guard with front mount hitch, 32" steering tires all around, ac power converter,jeep bucket seats, deezee runningboards (cab only),cobra 29 cb w/ 102" whip, 2 trucklight worklights on front stake pocket each side,high lift jack behind seat, toolbox for the junk, visor, running lights, 6600 lbs with all my junk
http://youtube.com/watch?v=ILAQuHNAGE0
i plan to add propane kit, stake body bed, gn hitch,western style mirrors, and a lot more
88beast is offline
Old 12-26-2007, 11:46 AM   #3 (permalink)
I believe doors from '83-97 will fit. As long as the truck it came from is the same body style (or from the '80's), it should fit.
1985 F-350 6.9 IDI w/101k miles, RC, 4x2, DRW, 4.10 gears, ZF-5speed, 5" stack, manual glow plugs, flatbed, buckets and center console off a bronco and no soup bowl!
Pics.:
My Truck
Up next: Turbo, full instrumentation, hydroboost brakes
F350farmboy is offline
Old 12-26-2007, 05:14 PM   #4 (permalink)
The doors will bolt on just fine, however the door panels are made to match the dashes of each generation, and they will look funny mismatched. The mid 90's dash and door panel are made to "flow" together.
*ASE Master Certified, Medium & Heavy Trucks*
Mr_Roboto is offline
Old 12-27-2007, 12:12 AM   #5 (permalink)
arthurgoboom's Avatar
I think the outside body lines from 80-96 are all the same, but like Roboto said, the interior panels are different, and the vent window is a little different on the 92-96 model so it'll clear that "flowing" dash. It might look strange but it should work. The window track is integrated with the vent window assembly, it's probably rusted away down at the bottom (mine were) or the rubber/felt window guide is cracked/rotted.
1986 F250 2WD Super Cab XLT Lariat w/ 1996 front clip. Dually bed & van rearend (2" wider, allows spring clearance). 6.9 w/ approx 120,000mi. Banks non-wastegated turbo system, Beru ZD1A glowplugs, Delphi BB injectors, Kenworth pyrometer, vac/boost gauge, electric water temp/oil psi/voltmeter mounted in dash. 3" Mandrel-bent open exhaust. C6 trans, 3.54 gears. Okiegringo idler pulley. R134a A/C conversion. WMO/diesel blend in one tank.
arthurgoboom is offline
Old 12-29-2007, 11:46 PM   #6 (permalink)
Thanks for the info guys. The styling of the dash never even crossed my mind. I will just stick with the same style so it doesn't look fugly. If the current dash wasn't so hard to remove I would swap that too, but it's a pain.
sunray is offline
Old 12-30-2007, 12:14 PM   #7 (permalink)
To fix your original problem, you could find a good door from anything up to '96 and transfer all of your hardware into it. The metal door shell should be the same, and all of the stuff (power window mechanism, door handle, interior panel, etc) should transfer over onto the other door. You could just hunt around in the junk yards for an 87-91 with a good vent window assembly to fix the window-off-track problem. It's not bad to remove in the field, you can do it all with hand tools. When searching for mine I found differences between mine (86) and a couple with 87-91 body style, so that is year specific.
» Sponsor Links
»Garage Storage and Cabinets
