First make sure your vacuum pump is not the fault. If it is the booster, remove the vac. line and check valve. Then inside, remove the cotter pin on the brake pedal arm. slide the pushrod off the arm. Unbolt the four nuts holding the booster. Then pull it out from the firewall. That's it.
I just replaced my vacuum pump and I tested it by simply taking off the vacuum hose at the T by the firewall and seeing if there was any air getting sucked in by the pump. You could also loosen the belt and see if the vacuum pump pulley will turn easily by hand (indicates bad vacuum pump.)
1989 Ford F250XLT Lariat extended cab 4x4 w/ N/A 7.3L, C6, 120k miles, & FlexSteel seats. Stock right now, but have a used non-wastegated Banks Turbo sitting in the garage (trying to find the time to collect the parts and install it) [img]/ubbthreads/images/graemlins/cool.gif[/img].
03/06 - Auto-RX done. Filter looked normal.
04/06 - Installed 100gal in bed tank for WVO.
11/06 - New rotors & pads
I did the vacuum test and found that the vacuum pump was pumping low. I bought a replacement vacuum pump, pulled the pulley off the old pump with a pulley puller.
How do I install the pulley onto the new vacuum pump? Do I need a pulley installer?
Getting closer,
Hugh
1991 F250 XLT, 2WD, 7.3L IDI, 5 speed, 168K.
Find a 2 inch long bolt that will thread into the center of the vac pump shaft, put a nut & washer on the bolt and then turn the nut, while holding the bolt this will pull the pulley on. If you can use a 3/4 inch - 1/2 inch drive socket instead of the washer and this will make it even easier to bring the pully onto the shaft at the correct depth. [img]/ubbthreads/images/graemlins/smile.gif[/img]
Bob
My Pictures
1984 Bronco II 4x4 day to day driver : Winter
2005 Explorer Sportrac 4x4 day to day driver : Summer
1991 F350 / Crew cab , Engine 7.3,E4OD tranny. No Turbo but has propane and pyro gauge. The truck is American, complete with a Miles per Hour speedo. Digital trans. temp gauge and voltmeter. Front Captain seats. Control switches for DRL's , Fog lites, High speed idle, Engine kill and scene lites. On board " York " compressed air, Air horns and built in hose reel behind the rear seat. Power bar distribution box from a 1999 Ford Explorer . Checker plate running boards and Frieghtliner mud flaps. LED turn signals in the factory mirrors. DC to AC inverter to run the coffee maker <img src="/ubbthreads/images/graemlins/smile.gif" alt="" /> Soon to be updated with more toys as time & $$$ permit. <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />
Hugh, Like Willie said, you need to rig up the proper length bolt/nut combo to pull it on. Last time I did this, I got the pump from the stealership (ouch) and it came with the bolt and washer for replacing the pulley. If you put a stove washer on the bolt and run it down until the pulley is flush with the end of the pump shaft, you're done.
Keith
93 F350 CC Dually 7.3 Hypermax turbo 4:10 gears, ZF rower, K&N filter, home made ram-air, Hypermax 3.5" exhaust, LUK clutch, 150,000 mi.
Getting the pulley ON took a little time, thanks for the advice.
After reinstalling the vac pump tonight, I checked the new vacuum = 24 inches Hg, compared to 15 inches (old worn pump). Thanks for the help Pete, your vacuum diagnostic info sheet worked great!
All I have left is to return the old vac pump for core $$.
Final question: Why didn't my low vacuum pressure switch light up? My brakes weren't working and the Brake dash light was not on. Is it just an idiot light that lights when you have very very low vacuum or none? It came ON when I disconnected it. Wondering if I should replace it if it was supposed to work better than it did.
Hugh, when my pumps have died it was catastrophic- no warning and boom- gone. Then the brake light came on. So maybe there is a min. vacuum required to keep the idiot light from lighting up and you didn't get that low?? Dunno, but maybe you wanna see if the bulb is good?
Keith
