Brake light, Anti lock rear lights. - Diesel Forum - TheDieselStop.com
post #1 of 17 (permalink) Old 03-29-2009, 02:05 PM Thread Starter
Zacharynels's Avatar
I have noticed in more trucks than just mine that these pesky lights tend to stay on for no apparent reason (to me anyway).
My red Brake light and yellow Rear Anti-lock lights are both on while my truck is running. Like I said, I have been in and seen other IDIs, in videos with these same lights on. Is these some kind of issue with the brake light malfunctioning regularly in Model IDI Fords?
If anyone has the proper solution to these lights, please let me know.
Also, I don't have my owners manual too by the way, does anyone have an online version for 1989 F250 7.3 XLT Lariat? I would appreciate it, cannot find one online.
Thanks guys.
(SOLD!)
1992 Ford F350 XLT 4x4 7.3I 5 speed. Stanadyne IP, turned up, Skyjacker lift, D60 front end, Rear locker, Two piece flywheel, Differential drive shaft, Brake booster, 5th wheel, 5" stack, 38x15.5 Super Swampers on Mags and lots more...
Zacharynels is offline
post #2 of 17 (permalink) Old 03-29-2009, 02:40 PM
trugertha's Avatar
the only time i had my lights on there was something wrong with the rear abs.. light also comes on with low vaccum
1991 ext'd long box
7.3 idi E4OD ttb
264,000kms
had 162,000kms when i bought it 3 years ago
trugertha is offline
post #3 of 17 (permalink) Old 03-29-2009, 02:43 PM Thread Starter
What kinds of things go wrong, most of the time, with the abs on this truck?
(SOLD!)
post #4 of 17 (permalink) Old 03-29-2009, 03:09 PM
chuckster57's Avatar
Mine too. the brake light will come on if there isn't enough vacum in the system and the ABS light is supposed to come on when you turn the key to "on" and then it will go out. It you have both lights on while your driving down the road then you got problems. CDNSARGUY has in his photo gallery, the test for the vacum pump. There is a thread on here about the ABS light and how to get those codes. the abs light could be no more than the speed sensor in the rear diff. but I would get the code(s) to be sure.
Train Horns:
PM please not visitor message
chuckster57 is online now
post #5 of 17 (permalink) Old 03-29-2009, 03:22 PM Thread Starter
I was worried that BOTH were on while driving, I had planned to check the fluid levels just to make sure that's not all it was. But the ABS light at the same time I had a feeling it was something more than that. I have never messed with any vacum lines or anything with them. I will have to check out that thread and the ABS code thread... I'll need that too. If anyone has those links easily available lemme know I would appreciate it. Gonna check out those vacum pump test pictures in CDNSARGUY 's photo album.
Thanks man, big help.
(SOLD!)
post #6 of 17 (permalink) Old 03-29-2009, 03:34 PM Thread Starter
I just went through CDNSARGUY's 74 photos and couldn't find those pictures, are you sure he still has them?
(SOLD!)
post #7 of 17 (permalink) Old 03-29-2009, 04:06 PM
Vacuum test Part 1 of 2 - TheDieselStop.Com Photo Hosting
Vacuum test Part 2 - TheDieselStop.Com Photo Hosting
Here you go
Train Horns:
post #8 of 17 (permalink) Old 03-30-2009, 06:06 AM Thread Starter
Hey thanks again man.
I'll see if I can read this gibberish this afternoon
(SOLD!)
post #9 of 17 (permalink) Old 03-30-2009, 08:52 AM
You can read about the ABS systema and how to retrieve the codes Here:
Kelsey-Hayes RWAL Antilock Brakes
Train Horns:
post #10 of 17 (permalink) Old 03-30-2009, 10:37 AM Thread Starter
Man you have the answer to everything on this forum!
Thanks a lot. I will check all this out in detail this weekend and hopefully get it figured out.
(SOLD!)
post #11 of 17 (permalink) Old 03-30-2009, 11:05 AM
not everything, but with the help of others, we have just about everything covered.Thanks for the vote anyway
Train Horns:
post #12 of 17 (permalink) Old 03-30-2009, 03:57 PM
My Photos: (10)
Check everything brake related; emergency brake (sensor need adjusting?), vacuum pump starting to die (mine did), brake fluid level, air in the line?.....
92 F350 XLT Crewcab dually, 225K miles ATS turbo, 4 inch exhaust, fresh IP & new matched BB injectors, Holly Red pump, K&N, E40D, 2 aux coolers, A-pillar guages, 410 limited-slip rear, Rancho 9000s, towing package, full running boards, mud flaps, 94' Ford (Alcoa) aluminum wheels, Predator camper shell, 600 watts of Sony/Boston Acoustics! Complete engine rebuild at 176k miles. Ford reman E4OD at 204k miles.
2001 Komfort 26FS
Fozz is offline
post #13 of 17 (permalink) Old 03-30-2009, 10:39 PM Thread Starter
How much is it for a new vacuum pump and how hard is it to install?
(SOLD!)
post #14 of 17 (permalink) Old 03-30-2009, 10:49 PM
Vacum pumps run about $125.00 and they are very simple to install. You may need to have the pulley pressed off the old one and pressed on the new one like they do on P/S pumps. Harbor Freight has the set to do this for about $10.00 You can't use a gear puller.
- Harbor Freight Tools - Quality Tools at the Lowest Prices
Train Horns:
post #15 of 17 (permalink) Old 03-30-2009, 10:55 PM Thread Starter
That is good news! And, if I do end up buying a new pump then I will definitely pick up that kit, there is a Harbor Freight Tools not far from here. Thanks for the advice. And, you should check out my new thread about mods/upgrades. Thanks again
(SOLD!)
