Re: brake master cylinder
You might be thinking of the master cylendar out of a one ton super duty which is hydraulicaly assisted from the power steerind pump, indeed a better setup but I would see it as being a big hassle to change. I am not sure if all the bolt holes are the same as the vacuum assisted setup. Though I think that may be the one you are refuring to.
3 X 06 Ford F250s 6.0 stock 4X4, just got two more, so now 5!
2003 Ford F250 4" Lift, Chipped, 4X4, Diamond Box
2000 Ford F250 7.3 PSD, 4X4, Stock
1999 Ford F350 7.3 PSD, SRW, 4X4, Chipped
1994 Ford F250 7.3 IDIT, 4X4, Pump cranked way up, fuel milage down way low, 6 inch lift on 315/75r16, still rides like a caddy for its day.
And I grow asparagus.
