I've had the lower radiator hose blow off twice now, & the radiator shop guys checked it out this time & couldn't find anthing wrong with the system. He suggested I check the motor mounts because maybe the engine was torqueing over & pulling the hose off.
So.. is there an eay way to check se if they're broke?? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Thanks, jerry
'91 F350 CC,7.3NA w/K&N,E40D(rebuilt--way too many times), 2WD,3.55 rear end,new IP,new u-joints & carrier bearing, new rotors, new calipers, new drums & hdware, added Auburn limited slip unit (2/8/05)w/valvoline synth 80-90w, new batt.cables,new window motors,new radiator & hoses, 500K, (new injectors)+ mi (now 678K miles)& still Truck'n. If I can fix it, it ain't broke, I'd rather do it myself.(yes, I add,stanadyne, lucas or power sytems fuel additive in every tank, w/maybe 1-2x year full big bottle dose split between both tanks). New tires & pretty wheels, front end rebuild 3/17/05. Bilsteins added 6/12/05. New motor mounts & valve cover gaskets (9/06.)Future hopes finally fixing my electric door locks & adding remote entry/alarm system. http://community.webshots.com/user/jl_mendoza
yeah, If you have noticed a jump like something is falling down on your truck. Or put it in drive holding the brakes or the clutch and watch the engine. ( becareful doing this) If the engine loooks like it is going to flip over in the dog house or better yet get under the rig and observe the engine mounts and if not sure just lift the engine with a jack to see if it seperates from the mount.
David and his Ford truck with a little motor and a big idea......
Ford F-350 Dually Crew Cab 5-Sp 7.3 IDI Centurion Conversion. No mods, rebilt IP and replaced injectors. Used as personal driver and pulling my RV camper.
Planned upgrades are a new and better turbo and larger exhaust pipes than the 21/2s that are already under the rig/ would like a 6 spd tranny but dont know if that is a feasable or smart investment yet.
1993 Dodge 3/4 ton Van Conversion 318CI
1978 Dodge Magnum XE T-top Classic 4BBl 400CI (Honeymoon Car)
1965 Dodge Polara 4 DR 383CI
Thanks David, I haven't been driving it much since the hose blew off. (my wife has been in the hospital since early January) so I haven't had much of a chance to check it out during the daylight. Just found broken upper motor mount on 2001 Neon wind up car, guess I'll have to check lower mount next, on that car. Then check my F350 soon.
jerry
