BUDD HUBS / SPACERS - Diesel Forum - TheDieselStop.com
post #1 of 2 (permalink) Old 03-23-2005, 10:52 PM Thread Starter
BUDD HUBS / SPACERS
I had a fellow contact me today about budd hubs on his dana 60 front end . He had purchased a spindle and rotor off of a dana 50 , and he as well as I were under the impression that the bud spacer either bolted onto the rotor or slid over the wheel studs . What he found was that the spacer , according to him , was made onto the wheel hub and he now is unable to use the set up that he just bought . My question to all you guys out there with budd front wheels is can this be true ? I'm not saying that this is impossible , only that I've never seen this type of perminent spacer set up . I do believe that the truck in question is a 90 or 92 F350 factory 4X4 .The dana 60 that I installed in my truck had the removable spacers because the friend that I sold them to slid them onto his dana 50 rotor/hub assembly and is using them today . Hopefully some one way smarter than me can set me straight on this issue .
94 F-250 XLT 4X4 REG. CAB , TINTED WINDOWS , PIONEER SUPER TUNER 3 WITH INFINITY GOLD SPEAKERS , FACTORY TWO STALL SPIT CUP HOLDERS, 7.3 FACTORY TURBO , REMOVED E4OD & ADDED ZF 5 SPEED , E4OD MAKES A GREAT PAPER WEIGHT , 4" SUSPENSION LIFT , SKYJACKER HYDRO SHOCKS , DANA 60 STRAIGHT FRONT AXIL ( FINALLY ) , 3"DOWNPIPE 4"EXHAUST KIT , 36" X 14.00" MICKEY THOMPSONS ON 16.5" ALUM. WHEELS , GOOSENECK HITCH EQUIPED , A-PILLAR GAUGE MOUNT WITH BOOST , PYRO & WATER TEMP. Totaled in April of '06
1992 F350 CC Dually XLT 7.3 NA with a broken Banks Sidewinder kit, gooseneck and reese hitchs, 234,000 mi and still going strong
2005 F-350 CC single wheel XLT Lariet 6.0, AT with ALL the goodies in the cab
JAYSON is offline
post #2 of 2 (permalink) Old 03-24-2005, 12:55 PM
Re: BUDD HUBS / SPACERS
All you have to do is remove the D50 hub which is the same as a dana 60 and install the dually hub. when I bought the dana 60 for my truck it came with dually hubs. I pulled the hubs and bought single wheel front hubs for my truck. They ended up coming off of a 3/4 ton with the dana 50.
Good luck
Junk
89 f-350, CrewCab, 4x4 (originally 2x4 auto), dana 60, 4-spd T-19 manual, us gear OD, NP208 transfercase, 40-20-40 bench seats front and rear, 97 aluminum rims, homemade front bumper/brushgaurd w/ receiver hitch, working fuel gauges (big improvement), overhead console with temperature readout, New steering box, Polyurethane bushings on front end, 4" exhaust, Explorer keyless entry,
Things in the works: NP205 transfercase, 94 factory turbo, 96 front clip, reverse shackle, fresh paint, coolant filter,
Currently Ripped apart.
junk is offline
