Burning Oil - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 04-14-2011, 08:18 PM Thread Starter
Burning Oil
hey guys on my 93 f250 7.3 every time i start it up there seems to be too much smoke...iam fine with that but during the winter when i start it there is literally a smoke cloud that comes out of the pipe and its there until its warm. i am also fine with that but the thing is that i didn't check the oil level cause i didn't think anything of it but after lets say.....3months i had LITERARLY NO OIL. it was dry...is my truck suppose to be burning this much oil? it doesn't seem to be the problem during summer only during winter please help thank you.
Visit
1993 F250 IDI
2002 F250 Powerstroker
bendourek1 is offline
post #2 of 7 (permalink) Old 04-14-2011, 09:16 PM
cdnsarguy's Avatar
My Photos: (109)
DieselDon wrote this info.....
Oil consumption, and the proper checking of the oil levels in Ford diesels comes up periodically. Ford dipsticks are calibrated for hot oil. The 10 quarts in the IDI engines expand about 1/2 to 3/4 of a quart as the oil heats up, and contracts the same amout after cooling. If you check the oil first thing in the morning ( which I grew up doing ) the engines will all indicate oils level below full, but when checked hot, will ( after a 10 minute drain time ) the oil level is usually at full. If you are checking the oil cold, and keeping the level at full, you are actually over filling the engine which will burn of the extra rapidly.
Suggestion: Check oil hot after 10 minute drain time.
Don't add until level reaches add line ( 2 quarts ).
In my days at Ford this often cured, or at least improved, the apparent oil consumption complaints.
6.9-7.3 Engine oil requirements.
32F to 100F+........30wt
0F to 100F+..........15W-40
32F to way below freezing ........10W-30
With the new oils...... 0W-40 is a good choice too in extreme cold
Proud Canadian BOOB man too!!
cdnsarguy is offline
post #3 of 7 (permalink) Old 04-14-2011, 09:39 PM Thread Starter
wow this actually helps but somebody was also telling that it could be some pcv valve or something that its got to do with sending fumes back or something could that also be it?
Visit
1993 F250 IDI
post #4 of 7 (permalink) Old 04-14-2011, 09:45 PM
cdnsarguy's Avatar
My Photos: (109)
Do you know when to service your CDR valve?
All 6.9L and 7.3L diesel engines are equipped with a CDR (Crankcase Depression Regulator) valve. Even the new 7.3L Power Stroke is also equipped with the same valve. The CDR valve is one of the leading causes of head gasket failure in these engines. The CDR valve is responsible for controlling the pressure/vacuum in the engine crankcase, and seperating the oil mist from the air and returning the oil to the crankcase. The CDR valve should be serviced every second oil change or when signs listed below are seen.
When the CDR valve is not properly serviced, engine oil enters the air intake and is drawn into the engine. The diesel engine will burn this oil as fuel, however, it is heavier and thicker than diesel fuel and, having greater BTU output, causes excessive heat in the cylinder. Due to the intake manifold design, most of the oil will migrate to #7 and #8 cylinders; the last two cylinders in the rear by the firewall. The increased temperature here will cause the cylinder head to lift off the gasket and allow water or oil to leak out the back of the cylinder head where it meets the block.
To check your CDR valve, remove the air cleaner hold down bolt and inspect it. If the bolt is covered with engine oil mist, it's time to service your CDR valve! Ford calls this item a "Adapter assembly for Crankcase Ventilation" Part number E3TZ-6A665-A or IH part #1805319C1
To service the CDR wash with a solvent, allow to dry, do not use compressed air to dry. There is a small hole in the CDR back cover, ensure it is clean and open. If black chunks of rubber are visible in the intake, on the screen then the rubber membrane has disintegrated, replace the CDR.
post #5 of 7 (permalink) Old 04-14-2011, 11:13 PM Thread Starter
Wow thank you very much I think this might just solve my problem I have noticed oil dripping down from my heads.....
Thank you extremely! All of you
Visit
1993 F250 IDI
post #6 of 7 (permalink) Old 04-15-2011, 12:11 AM
lexxxel's Avatar
you might also have developed an oil leak... any oil on your driveway? Valve cover gasket leaks are common.
'91 F-250 7.3idi XLT Lariat Supercab
Non-Turbo, Bone Stock
E4OD 4x2 4.10 non-posi
6 digit odometer
122,000 miles (197,000km)
still Minty Fresh
Sold my old 90 reg cab @340,000 miles (550,000km)
Still running I'm sure...
lexxxel is offline
post #7 of 7 (permalink) Old 04-16-2011, 03:46 PM Thread Starter
actually ye just a little bit...i can see little oil dripping down my oil filter...i thought it might be just not screwed in all the way...
Visit
1993 F250 IDI
