Re: A/C in Cab Drip and Belt Squealing
My first suggestion would be to check the area between the rad and the A/C condesor for chaff and crud. Seen too many rads and condensors with a bucket load of garbage stopping the air travel required.
Check with your Ford dealer see if has this kit...
Idler kit
Idler pulley, 2 covers and bolt Motorcraft # YS 262
If the belt is too long or your idler is too small then you will get a squeel on shutdown, the engine stops faster than appliances ie alt etc.
I use a GATORBACK poly-v belt GDY 406112
Proud Canadian BOOB man too!!
