A/C engaugement - Diesel Forum - TheDieselStop.com
Old 02-13-2010, 10:45 AM   #1 (permalink)
A/C engaugement
Was wondering if anybody knows which wire is the one that activates the ac pump? My compressor does not seem to be kicking in.
94'IDI XLT X-cab 4X4 Factory turbo ATS upgrade kit,2.5" lift,hypermax intercooler,zf5,2000 northern lite 10'2"
cormann2 is offline
Old 02-17-2010, 07:58 PM   #2 (permalink)
I can't tell you right off the bat but I do remember that if the system does not have enough pressure in it the compressor will not activate.
1990 F350 crew cab,4x4,auto,ATS wastegated,Double a pillar mount for pyro and boost,tranny temp in dash, 3:55,216k. , 285/75/16 toyo mt. New IP dec. 03, pulled and painted engine dec. 03,
whlmn is offline
Old 02-17-2010, 11:18 PM   #3 (permalink)
cdnsarguy's Avatar
My Photos: (109)
Check this out.......
TheDieselStop.Com - www.thedieselstop.com
Proud Canadian BOOB man too!!
cdnsarguy is offline
Old 02-18-2010, 01:37 AM   #4 (permalink)
branmala's Avatar
Ok on the firewall on the passenger side there is a canister with a two wire prong on it. If you jump the wire and the ac pump comes on then you are good. (just have to charge the ac system). If you jump it and nothing happens then you might have a bigger problem on hand. But from my experience if you havent thrown a belt off the ac compressor then it is just low on coolent. and not locked up. But like i said im no expert.
Check out my solar info site http://www.solartax.info
1989 Ford F250 XLT Lariat 7.3 IDI non turbo, exetended cab, 100 gal fuel tank, 77,000 original documented miles (I know its hard to belive), ZF 5 speed with 4.10 rear end, all original looks and runs and drives like it did in 1989. Update- I installed 24 running board lights 12 per side, and installed 5 teardrop cad lights looks good!
1988 Ford F250 XLT 7.3 IDI exetended cab, C6 trans, 4x4, body and interior are in great shape, 187,000 original miles, runs good, new heads and full custom Holset hx60 turbo install with the brand new IP turned up 7 flats running at 850-1150 pre turbo on the pyro.
branmala is offline
