C6 Issues - Need Advice
Here's the vehicle: '87 F250 4WD, 6.9, C6, Gearvendor, 4.10 gears, almost 140,000 miles on the odometer, no history of repairs to the tranny. Tranny fluid looks normal, doesn't smell burnt.
Here's the issue: While going up a fairly steep, but short hill in town, in low gear, I only made it about halfway before I slowly came to a stop, engine turning about 1600-1800 rpm. GV was off. Had to back down and go around. Never had this problem on this hill before. The tranny seemed to shift normally on my alternate route home, shifted smoothly into each gear at about the right speed, although on the steeper parts of the hills I have to take, the tranny felt like it was slipping slightly (i.e., higher rpm than normal for the speed), but nothing drastic. Yesterday, on a milder hill about 1 block long on a residential street, I also had trouble getting to the top. Made it OK, but it seemed like it was slipping at slower speeds in low gear. (Again, nothing drastic, just seemed like higher rpm than usual for the speed, but I wondered if I was going to make it to the top.)
Before I take the truck in to the tranny shop and spend $$$ I don't have, does anyone have any ideas of what may be happening and whether there might be a fix that doesn't require a teardown (and can be done by a rank amateur shadetree mechanic with no auto tranny experience)??
Thanks,
Bob Bills
Bob Bills
KG6LMV
Orange County CA
1987 F-250 XLT Lariat, 4x4, Reg. Cab, Longbed,with Callen camper, 137,000 miles. Normally aspirated 6.9 with Hypermax cowl induction, Racor fuel filter. C-6/1356 tc/GearVendor/4.10 posi/33 BFGs. Stanadyne in tanks and Jeep in tow.
http://outdoorwire.com/4x4/jeep/home/jeep-l/billsr.htm
