Old 04-11-2005, 07:09 PM   #1 (permalink)
C6 - Locking Torque Converter?
I have a C6 in my truck, and will be doing some pretty heavy towing with it. 30ft 5th Wheel (7700lbs dry). I have been following the thread on the exhaust brake, and noticed the mention about the locking torque converter with a ground wire. I am assuming this is for the E40D? Is there a way to do this on a C6?
Ryan
1988 F250 Supercab, 4x4, 7.3 IDI, C6 Auto, 147K miles
Banks Sidewinder non-wastegated Turbo, Stage 1 Injectors, and Pyro, Boost and Water guages.
My Gallery
analog is offline
Old 04-11-2005, 09:34 PM   #2 (permalink)
My Photos: (21)
Re: C6 - Locking Torque Converter?
Great Question Ryan, I am wondering the same thing. I know that you can't do it electronically, but does anyone know if there is a lock up TC for a C6?
Of a HD TC that is built for towing?
"Big Ed" Cummins Powered 1989 F-350 XLT Lariat, King Ranch, Crew Cab, 12V Cummins, PSD Intercooler, 4x4, C6, Gear Vendors, 4:10ls, Propane Injection, Hood Scoop, Air Compressor/Horns/Bags/Tank/Conditioning, 17x10" wheels, 35" BFG's, Dual 5" Sidepipes, Edlbrock Shocks, Dual Steering Stabilizers, Add a Leafs, Full Guages, Custom Counsol, CD, Amp, Sub, Rear Power Slider, Brushguard, Headache Rack, Spray in Bedliner, Diamond Plate, TCI Deep Trans Pan, Super Duty Cooler, and Aux Filter, Amsoil Dual Oil FIlters and Synthetics, Lots more,... check out the video,..
Click Here for Big Ed's "Extreme Truck Makeover" Video
DarrinTosh@gmail.com
Darrin Tosh is offline
Old 04-11-2005, 09:39 PM   #3 (permalink)
My Photos: (13)
I think BD power makes a really HD TC for the C6, not positive though. I thought I saw it on the DIS website, might be worth checking out, I was going to go along that route when my tranny fails. Scotty
Semper Fi
Scott Beretz
2006 Dodge Megacab 4x4, Cummins, 6 Speed, Airbags, Quadzilla Commander, XZillaraider 2, 285/75R17 Toyo OC AT's
Pulls a: 3814SS Keystone Raptor Toyhauler w/Quads
beretzs is offline
Old 04-11-2005, 09:44 PM   #4 (permalink)
My Photos: (13)
Here is the link for those TC's from DIS. http://www.dieselpage.com/bdebf.htm
Might be a decent option and they are only 400.00 some odd bucks. Could make a good difference for the C6. But really, in stock form it is a pretty HD unit. Scotty
Semper Fi
Scott Beretz
beretzs is offline
Old 04-12-2005, 11:36 AM   #5 (permalink)
Thanks for the link Scott. I'll be looking at one of those when the time comes for tranny work.
Ryan
My Gallery
analog is offline
Old 04-12-2005, 05:12 PM   #6 (permalink)
My Photos: (16)
TCI also offers a heavy duty TC for the C6 diesel app.
Poke here
'93 F250 SCab XLT, 4X2- 7.3/ZF5/4.10 Banks Wastegated Turbo, Enviro-assult tube
'85 F250 Reg Cab XL, 4X2-6.9/C6/3.54 Racor, Holley Red, Auto Jet 3" out, Air Ride Rear
'93 F150 Reg Cab XLT, 4X4-5.0/AOD/3.55 Pacesetter dual out, Timbren Rear
Some pix/ The fleet
Zrob is offline
Old 04-12-2005, 07:24 PM   #7 (permalink)
asauer's Avatar
Send a message via MSN to asauer Send a message via Skype™ to asauer
This is off-topic, but will a C6 out of a 460 bolt up to a 7.3L? I have heard that the bellhousing pattern is the same, and I've heard it's different. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
--motor/trans sold--
2000 VW Jetta TDI = 48+mpg
1997 Dodge 3500: 2WD Cab & Chassis, 12V Cummins, 47RE Automatic, Dana 80, 194,000mi. Parting out.
1989 12V VE Cummins out of Chevy C60? at the machine shop...going into the Ford.
Member of Indiana Air National Guard 122FW MXS
asauer is offline
Old 04-12-2005, 07:31 PM   #8 (permalink)
patterns are differant--the best tc for a c6--have a reputable shop lower the stall as low as you feel comfortable with---less slippage on the open road----
94_turbo is offline
Old 04-12-2005, 08:20 PM   #9 (permalink)
My Photos: (16)
I'd guess that's exactly what TCI does:
"TCI®’s Truckmaster torque converters are state-of-the art components built to handle the extreme demands of today’s Ford Powerstroke turbo diesel truck owners. With increased strength, lower stall speeds and heavy duty Torrington bearings, they reduce internal heat increasing the longevity of the entire transmission."
Some pix/ The fleet
Zrob is offline
Old 04-12-2005, 08:25 PM   #10 (permalink)
My Photos: (13)
The only thing about that ad, was that it listed the 7.3 powerstroke with a C6 and we all know the IDI was king during those years, and the 7.3 IDI wasn't offered very long before the the E40D made its debut, but it does sound like a better converter than a stock one. Hard tellin, it would be nice to have one of their RV trans when the one in my truck fails. For 1K bucks, couldn't be too bad of a deal. Scotty
Semper Fi
Scott Beretz
beretzs is offline
Old 04-13-2005, 04:53 AM   #11 (permalink)
My Photos: (16)
I noticed that too, Scott. I'm sure it's just a generic ad. The ad for the 6.9/7.3 and DI all read the same, except for the application years and part numbers.
$100 cheaper than DIS, though. I know BD has a great rep, but so does TCI.
Some pix/ The fleet
Zrob is offline
Old 04-13-2005, 07:34 AM   #12 (permalink)
the C6 wasn't offered with a C6, well at least not very long before the the E40d made its debut,
I assume you mean the C6 wasn't offered with the Powerstroke, because the C6 was always offered with the C6. [img]/ubbthreads/images/graemlins/grin.gif[/img]
The C6 was offered with the Powerstroke through the 1996 model year. They are rare, but Ford did build some.
Casey_1 is offline
Old 04-13-2005, 04:30 PM   #13 (permalink)
My Photos: (13)
I ahve never heard or seen a C6 tranny in a Stroke, I thought the E40D replaced them all. News to me. Just a rookie here. Scotty
Semper Fi
Scott Beretz
beretzs is offline
Old 04-13-2005, 09:25 PM   #14 (permalink)
My Photos: (21)
1989 Was the last year for the C6. Some 89's have the C6, some have the E4od. After that the C6 was no longer avaliable.
Even when the PSD came out in 94 1/2, you could only get it in an 5 speed. Then in 95 on up you could get it with the E4od.
Old 04-14-2005, 07:54 AM   #15 (permalink)
I've seen C6 Powerstrokes and 460's through 1996. I do know that the plant kep building them until July, 1996.
Casey_1 is offline
