cab mount bushing measurements - Diesel Forum - TheDieselStop.com
Old 11-14-2009, 02:26 PM   #1 (permalink)
RWF350's Avatar
I need to replace my cab mount bushings. I want rubber. I found "universal" bushings at broncograveyard.com. I do not have measurements of the o.e. bushings(or even the poly bushings) to decide if/how to make these work (mine are collapsed). Does anybody have these specs from either rubber or poly? I could work with measurements from either.
ps: National Parts Depot shows a rubber bushing set that's pretty cheap. But they are out of stock and have no eta of a next shipment.
2007 Chevy 2500HD 4WD Ext Cab (late model) 6.0L (gas) 6speed auto
Deceased--1990 F350 2wd DRW Super Cab E4OD 7.3l IDI
Gooseneck hitch, Flowmaster (single inlet/dual out), 60 gal tank/toolbox/bedrails/headache rack (custom built, welded together as 1 unit), 3 gauge pillar pod w/glowshift gauges, oil, water temp, trans temp
Never ask "What else can go wrong?" cause something will.
RWF350 is offline
Old 11-14-2009, 06:55 PM   #2 (permalink)
rmr
Did you try LMC?
LMC Truck Parts - Page 31
I just got some stuff from them, they are pretty fast.
1986 F250,Regular cab,XL,4X4,6.9, 4 speed,
2006 Chevrolet Silverado 2500HD, 6.0,gas, 4X4, reg cab
rmr is offline
Old 11-14-2009, 07:11 PM   #3 (permalink)
RWF350's Avatar
Yeah, the price starts adding up to do all 6 positions. There's gotta be cheaper way to get rubber.
RWF350 is offline
Old 11-14-2009, 11:00 PM   #4 (permalink)
cdnsarguy's Avatar
My Photos: (109)
Some use hockey pucks..... not my idea of a soft ride. Check with Ford they would be the best ones.
Proud Canadian BOOB man too!!
cdnsarguy is offline
Old 11-15-2009, 12:52 PM   #5 (permalink)
RWF350's Avatar
Ford wants approx $420 for a set. LMC and BOTC are a little less.I'm trying to put in rubber (or soft like rubber) on a polyurethane budget. Which may not be possible. The truck is a 1 ton, it rides hard enough already. I'm pretty picky, can't tolerate vibrations(stock ride has a few, and I'm fine with that), squeaks or rattles. With poly bushings it's got to be worse (I'm guessing from reading other posts). Which will probably leave me quite unhappy and quite busy trying solve it all. Most of which, I would think harder ride = problems like cracked rad. core supports and things of that nature. To add more fun to it, it's a daily driver and I'm not off 2 days in a row. So when I work on it, I usually have 24hrs or less to get it back on the road.
RWF350 is offline
