Old 11-11-2007, 07:46 PM   #1 (permalink)
In cab wiring please help me fix this new nightmare
ok guys now that the truck runs great i also noticed the tach dont work proprly it says liek 50rpm when idling and well idk the tach just asks funky and i know its not a true reading. also whenever i hit anyothr electronics like turn the light switch on for parkign or headlights all the guages in insturment cluster go nuts. Also i noticed i have 2 1100 cranking amp batteries and well it always seems liek the batterys are always low i check them on charger and they seem good. I noticed the ground wires to the batterys aren't to great at all so im goign to change the grounds. Also i noticed when puttign the parking lights on or the headlights headlights and parking lights in the front dont work. I know the parking lights work on the bed when i pull the switch on.
thanks,
jimmy
1993 f-250 7.3 banks turbo 3inch downpipe into 4 inch strait pipe and 4inch tailpipe comign out at 45 degree angle under bumper on passengerside. fuel cranked up Runs great!
*Current project*
1990 f-350 4x4 when bought had tons of problems and also had no tranny ot transfercase
4 speed tranny, transfercase installed, new injectors, advanced timing like it should be, new voltage regualtor, has meyers plow, new clutch master cylinder, I have wiring problems with it right now on the interior guages
94extcabf250diesel is offline
Old 11-11-2007, 10:38 PM   #2 (permalink)
Re: In cab wiring please help me fix this new nightmare
1. Remove the instrument cluster, clean the contacts where it plugs in.
2. Starter may be in bad shape from extended cranking.
3. Check the bulbs first, then get after it with a test light. The light switches are known to be unreliable.
A.K.A. Sign_man
1988 F-Superduty bucket truck, 7.3 IDI, LuK Clutch, 5 spd, 4.10 rear
http://photos.thedieselstop.com/show...=70062&thumb=1
Phillipmc1268 is offline
Old 11-11-2007, 10:47 PM   #3 (permalink)
suv7734's Avatar
Until you get good grounds you won't be able to isolate anything. You indicated the battery side looks bad but check the two connections at the block as well. Poor grounds will drive you crazy. Once you get the ground issue out of the picture you'll probably find there are fewer problems than there appear to be. Have a smell near the headlight switch, they have a tendency to burn up the harness and you'll be able to smell it if it's starting to go.
1988 F350 CC 4x4 SRW, 7.3 Banks non-wastegated turbo, C6 w/ HD torque converter, Tru-Cool 4590 trans cooler, Highjacker 'softride' 4" lift, pre/post luber, coolant filter, Racor fuel filter/separator, pyro and boost gauges, Progressive 16x8 wheels, 285-75x16 rubber, 3" downpipe into 4" straight pipe over the rear axle and into 5" SS tip. 1994 Alpenlite 33' 5th wheel trailer
suv7734 is offline
Old 11-12-2007, 12:05 AM   #4 (permalink)
91diesel's Avatar
Send a message via AIM to 91diesel Send a message via MSN to 91diesel
Think about replacing the tach sender. You can test but i dont know exact procedure, QUE CDNSARGUY. The sender is the big 1 inch nut on the ip gear housing. It has two wires coming out of it. I believe last time i checked it was a pretty cheap part and wasnt recommended to test and keep.
1997 F-350, XLT, dually, crew cab, 7.3 PSD, E4OD auto, B+W turnover goosneck hitch, ts 6 pos. chip,
http://community.webshots.com/user/91diesel
**91diesel AKA anthony2010**
http://www.youtube.com/watch?v=fe622W_yZcQ
16.66MPG
[IMG src=file:///C:/DOCUME%7E1/Owner/LOCALS%7E1/Temp/moz-screenshot-9.jpg][/IMG]
91diesel is offline
Old 11-12-2007, 01:11 AM   #5 (permalink)
yeah it looks liek on the one battery ground wire it looks liek somoen took it and stripped about 6inch logn section of the coatign then untwisted it and cut 1/2 of the wire so only half of the wire is still there actually making a ground. the other side dont look nearly as bad but im going to change both of them. then starter i think if fine because i think its mainly the grounds to the batterys (expecialy the one side i mentioned about) makign it hard to start. after the truck is runnning it seems like as soon as you try to use juice somewhere else it takes it away from the guages and makes them quit working or work improperly...
jimmy
*Current project*
Old 11-12-2007, 08:57 AM   #6 (permalink)
cdnsarguy's Avatar
My Photos: (66)
A dead tach sender should/would send the automatic trans into a "failure management mode" (limp mode) with harsh engagements and firm shift feel and an abnormal shift schedule. It has no effect on a manual trans only the Tach readings.
Check the wires where they exit the big nut on the oil filler housing, known to short out due to bare wire.....
Replace the tach sender on the oil fill housing a big 1" nut with 2 wires. Ford only part Engine RPM sensor E5TZ-17B384-A about $50. You can remove and clean it but usually changed later too.
You can test it too, hold it in the air away from ferrous metal, using an ohm meter lead on each wire you need DC resistance between 2000-3000 ohms.
Proud Canadian BOOB man too!!
cdnsarguy is offline
Old 11-12-2007, 12:00 PM   #7 (permalink)
88beast's Avatar
wow must be a fasctory fix mine is the same way about 6 in stripped off and twisted sround a bolt i plan to fix it when i can but that may explain the lack of reverselights the tach and fuel gauge not working and all the other problems
88 F-250 body,550 rear frame setup, 7.3 idi, 3:73 dana 80 rear, srw, dana 50 front, heavy duty leaf springs, back up camera, 20$ wallyworld fog lamps, class 5 bumper hitch welded to frame and gusseted, 32" steering tires all around, ac power converter,jeep bucket seats, deezee runningboards (cab only),cobra 29 cb w/ 102" whip, 2 trucklight worklights on front stake pocket each side,high lift jack behind seat, toolbox for the junk, visor, running lights, 6600 lbs with all my junk
http://youtube.com/watch?v=ILAQuHNAGE0
i plan to add propane kit, stake body bed, gn hitch,western style mirrors, and a lot more
88beast is offline
